R50/53 Random bad idle fluctuation
Old Mar 18, 2019 | 08:13 PM
Russter500's Avatar
Russter500
I have an 02 cooper s and I have an issue which almost always only occurs at the drive thru, when I move through the line once or twice, my car will start to stumble and then catch itself, and repeat a couple times and clear up. I have heard a load of times it is part of the ecu factory tune on the car. Well I just got it tuned today, and the problem actually got worse. Usually the idle will drop 1-2 hundred rpm, this time it dropped about 500 rpm, probably down to about 3-4 hundred rpm, it almost stalled but I gave it gas to recover it. It seems like getting on and off the gas quickly does something to cause this problem. So I’m pretty sure now it isn’t related to the ecu at all. Does anyone have any ideas what could cause this problem? I’ve replaced the pcv valve, the lines seem okay and aren’t collapsing. Could it be a map or tmap sensor? Any common vacuum leak areas? Any help would be great, thanks!
Old Mar 18, 2019 | 08:46 PM
BlwnAway's Avatar
BlwnAway
Common vacuum leak areas are, S/C boots, the hard vacuum lines to the S/C and the lines to the fuel regulator and BPV, pretty much all of them can succumb to heat related failures (cracking and drying)
As far as MAP or T-MAP, the T-MAP is that one that will effect idle most, and wear out quicker, but they usually go bad to the point it's extremely noticeable and not gradual at all.
But.... I still think you should be looking at the tune, contact the tuner and let them know the issue. If you just had it tuned and that changed something, don't overlook the obvious.
Old Mar 18, 2019 | 09:10 PM
Russter500's Avatar
Russter500
awesome that’s good to know, i will look into those possible leaks. And I’ve already contacted my tuner and will see what he says. And for the tmap sensor that will be my last resort effort, I will keep you updated on the situation. Thanks!
Old Mar 19, 2019 | 01:05 AM
SuN13300's Avatar
SuN13300
Idle problems that look "random" are in fact related to canister purge.
When the ECU opens canister purge valve it closes a little more the throttle at the same time, because air and fuel are coming through the canister lines.
During that purge, if you have a little vacuum leak somewhere at the intake, the purge controller cannot regulate throttle opening properly which causes lambda oscillations.
Another reason could be bigger injectors without a proper injector scaling in the tune. Again during canister purge the ECU has hard time regulating lambda because injected fuel quantity is not as accurate as it should.
Mini Moto
R55 :: Clubman Talk (2008+)
19
Oct 10, 2022 09:44 AM
IQRaceworks
Oct 27, 2015 08:07 AM
acouch12
Apr 7, 2010 03:30 PM
jackliu1980
Mar 16, 2008 01:07 PM
Beanbag
Oct 12, 2004 02:22 PM
