Suspension Factory JCW - OEM Suspension Replacement Part # Question
Old Mar 18, 2019 | 07:58 AM
equinox92's Avatar
equinox92
Hey did a bunch of searching but couldn't really find much. I've got an 06 factory JCW (without the sport kit, from what I can tell) and I've got a rear strut that has seen better days. I'd really like to replace just the rears, but am not opposed to replacing all 4 struts.
I don't need anything fancy, just OEM replacements.. but here's the trouble I am having. The JCW has different suspension that a standard Cooper S and (i assume) different than the GP.
I am using this website to find parts: https://parts.miniofkennesaw.com/
When look up the model, I don't see a JCW, just JCW GP and GP. The rear strut appears to be the same part number for both: https://parts.miniofkennesaw.com/pro...506776199.html
I guess my questions are:
-Are these the right OEM parts for my factory JCW without the sport kit?
-How can I tell JCW (non sport) suspension apart from S stuff?
The term JCW means too many damn things these days...
Old Mar 18, 2019 | 09:26 AM
Eddie07S's Avatar
Eddie07S
Try realoem.com. They do really well with car parts and numbers.
That said, the base suspension for the Gen I and Gen II MINI JCWs was called the “Sport Suspension”. This came with black springs. There was an optional JCW Sport suspension that came with red springs. Each of these were a step up in performance from the other. That is, the base JCW suspension was a step up from the S suspension (stiffer shocks, springs, and sway bars). The JCW sports suspension was another step up from that.
If you are just looking at replacing struts, if the rears are gone then the fronts are gone (or well on their way out), too. Here is a thread that might help you. Any of these shocks will work for you.
https://www.northamericanmotoring.co...fsd-vs-b4.html
Old Mar 18, 2019 | 09:50 AM
equinox92's Avatar
equinox92
Yeah I looked at some of those threads and I really just don't want to spend the money on aftermarket stuff. My Mini is my winter car anyways, and I just got new Ohlins coilsovers for my Impreza so replacements are what I am after.
Thanks for the link, will look through that.
Also thanks for the terminology. I have the "sport" suspension I suppose with the black springs, not the red.
Old Mar 18, 2019 | 10:06 AM
TVPostSound's Avatar
TVPostSound
Aftermarket struts will cost you less than OEMs.
Old Mar 18, 2019 | 12:12 PM
Yes, the factory struts usually cost more or are very close and the Koni Reds are super smooth for daily driving, our link is at the bottom of the thread above that eddie posted.
Old Mar 18, 2019 | 01:00 PM
Eddie07S's Avatar
Eddie07S
The Bilstein B4s also.
And, for less money than the MINI shocks, the B4s or the Konis are a better shock than the MINI shocks.
Old Apr 11, 2019 | 07:04 AM
equinox92's Avatar
equinox92
Ended up going with the B4s. They feel very much like stock JCW stuff, maybe a bit softer. I think the softness is coming from NOT hitting bump stops on blown factory suspension though, so take that for what it's worth.
Thanks for all the suggestions!
Old Apr 11, 2019 | 08:34 AM
Eddie07S's Avatar
Eddie07S
That is fantastic!
I think Bilstein does much better with their valving which may also play into their smoothness/softness feeling, at least that was my thought when I installed the B8s.
And, just in time for late spring and summer cruising.
Let us know your thoughts about them as you get to spend some time with them.
Enjoy and motor on!
wlkariz
Oct 12, 2018 04:59 PM
replacement
Mar 15, 2017 02:14 PM
gbuff1
Jun 19, 2015 09:06 AM
proscia116
Apr 14, 2015 03:35 PM
fm.illuminatus
Suspension
38
Sep 8, 2011 05:04 PM
