R50/53 Serpentine Belt/idler/tensioner...should I change?
Old Mar 9, 2019 | 06:31 PM
r53-06m6's Avatar
r53-06m6
I am replacing my alternator and was wondering if I should change these items out now. I am becoming a bigger and bigger fan of if it's not broken then don't fix it over the years but would like your thoughts.
I am not going to pay for OEM parts but want to know what brands people have had luck with. I am *assuming* that the supercharger pulley is stock as well.
Old Mar 9, 2019 | 06:58 PM
Tgriffithjr's Avatar
Tgriffithjr
How many miles? Gates are always good belts.
Old Mar 9, 2019 | 08:22 PM
Racingguy04's Avatar
Racingguy04
I replaced my alternator this past summer, I replaced the belt that had 30,000 miles on it, and wish I had replaced my idler pulley. I'm not sure I'd bother with the tensioner.
I bought this alternator and as far as I can tell it's the same as OEM.
Amazon Amazon
I also replaced my crank position sensor o-ring. Mine was leaking, but it's $5 and easy to get to when the car is in service mode.
Old Mar 10, 2019 | 08:22 AM
r53-06m6's Avatar
r53-06m6
Thanks for this. 144k....it's not the original belt. Notice that the belt and pulleys seem to have a "line" in the middle of them. I'd like to say "groove" but I can't see that far.
If you were going to go non OEM with the idler, what would you use? I usually go with Dayco or Gates.
I went with this alternator:
Amazon Amazon
Good reviews and new construction supposedly. Price is right. Not sure how much faith I'd put into these reviews since I don't know if the alternator will go the distance.
Old Mar 10, 2019 | 08:55 AM
Zsm's Avatar
Zsm
If you don’t know how old the belt and tensioner are, it would be best to replace them. The idler pulley is important too, though probably a less common failure.
If the tensioner or belt go, you’ll be dead in the water. An idler pulley will scream for attention letting you know it’s time. Check the belt for cracks and the tensioner for play. It starts to fail as the little strut loses its ability to dampen.
Old Apr 10, 2019 | 10:44 AM
Mini invictus's Avatar
Mini invictus
Out of curiosity and hope, what kind of "scream" does the idler pulley make when it has failed? What should I look for to see that it has failed? I am guessing it will have play and slop going side to side.
Old Apr 10, 2019 | 10:49 AM
gumbedamit's Avatar
gumbedamit
There will be a low level continuous bell sound. I have the same line in the middle of my belt, don't think is't anything to worry about, I had it on my last belt that was changed due to a 15% SC pulley change. I currently have 30K on my current belt with the same line down the middle.
Old Apr 10, 2019 | 11:12 AM
Mini invictus
Hmmmm, not as similar sounding as I hoped. But I plan on changing it as well regardless.
Just a thought, maybe the line is from the idler pulley, if the line is a groove then probably not. But if it is more of a bump it might be from that since the idle is two pieces placed together.
Old Apr 10, 2019 | 12:10 PM
gumbedamit's Avatar
gumbedamit
It is from the Idler Pulley, nothing to worry about. It's hard to describe the sound of the pulley failing, it's like a shrill sound. When mine went, I'd would be sitting hearing a Shrill type whine, very faint. Just to be clear, even after you change the Idler Pulley, that line will come back, it's not a problem or defect.
Old Apr 10, 2019 | 02:19 PM
SupeR53's Avatar
SupeR53
I just replaced my alternator, put in a new belt (old one only had 25k on it) and bought an idler as a matter of course, since I was that far away from it, I was very happy to find that the idler pulley was failing, its one bolt, and ~$20 bucks of good insurance. The tensioner was almost near the end of its travel before I started, and close to the other end of travel after a new idler and belt. I used a Gates HD (green back) belt, it should last longer than I'm willing to let it stay on the car
Put a new idler pulley in, its cheap insurance.
JMHO,
Old Apr 11, 2019 | 07:20 AM
MINI33342's Avatar
MINI33342
You are going to have issues with that alternator. Get a Denso oem one, new belt, idler pulley, and tensioner as they will all be ready to replace very soon. Cheaper to get the right parts now.
Old Apr 11, 2019 | 08:33 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've replaced many aftermarket failed alternators, so I'd go with OEM
https://www.waymotorworks.com/altern...-cooper-s.html
check the idler and replace if the bearing isn't smooth.
The pulley is just for fun, but the best bang for the buck
https://www.waymotorworks.com/wmw-pulley-package.html
Bernie (NoVA)
Nov 20, 2017 10:32 AM
CRC
Feb 14, 2017 08:14 AM
daonlyillwiz
Feb 4, 2014 06:28 PM
joka
General Mini related Ads
Dec 10, 2012 12:10 PM
jlm
Jun 12, 2005 11:39 PM
