Need help bad!! Slave cylinder replaced but won't go into gear with it on
Old Mar 2, 2019 | 08:52 AM
Chey Horton's Avatar
Chey Horton
So I replaced my slave cylinder and got the car running again but with the engine on she still won't go into gear. I've got a 2002 mcs and with the engine off I can cycle the gears but once she's started I can't get her into any gear. If I start her in first I can pull it out of first and put it in first with a lot of force and I can even cycle the rest of the gears with the same amount of force but only if I start her in first then pull it out of first
Old Mar 2, 2019 | 09:02 AM
Tgriffithjr's Avatar
Tgriffithjr
Did you bleed it completely. Also isn’t this the same issue you posted about on the 25th?
Old Mar 2, 2019 | 12:44 PM
Chey Horton
Yes and yes .sorry I seem to post alot on here. I also held the clutch down over night to see if it's help
Gumbob3
Feb 7, 2022 11:50 AM
Chey Horton
Feb 26, 2019 09:39 PM
bdubya
Mar 6, 2017 10:47 AM
liabear
Dec 24, 2010 11:55 PM
mach schnell
Jul 21, 2010 09:54 PM
