Is this my supercharger that has gone bad
Old Feb 20, 2019 | 10:07 AM
Sayvion Ralph's Avatar
Sayvion Ralph
Is this my supercharger that has gone bad ????
I am going to attach a video of the sound coming from somewhere under the hood I feel like it may be the supercharger
Old Feb 20, 2019 | 10:14 AM
Sayvion Ralph
this is the link to the video of the sound coming from my engine bay I feel like it is my supercharger that has given up
Old Feb 20, 2019 | 10:16 AM
IQRaceworks's Avatar
IQRaceworks
What year is your car? Does it have a turbo or supercharger?
Old Feb 20, 2019 | 10:17 AM
IQRaceworks
Yep.....I think you hit the nail on the head. Are you down on power? Getting a check engine light? Any codes?
Old Feb 20, 2019 | 10:18 AM
Sayvion Ralph
No I’m still getting the right amount of boost and no check engine light
Old Feb 20, 2019 | 10:20 AM
IQRaceworks
Does it run fine? It's not down on power? Kind of odd. Maybe some others will chime in.
Old Feb 20, 2019 | 10:21 AM
Sayvion Ralph
It runs completely fine it’s a new engine and gearbox in it the only thing that hasn’t been changed is the supercharger
Old Feb 20, 2019 | 10:25 AM
IQRaceworks
How many miles on the supercharger?
Did that supercharger make that noise on the old motor?
If it didn't make that noise on the old motor, when did it start making noise on the new motor? How many miles on the new motor?
What boost numbers are you seeing? Stock pulley? If not...what size?
Old Feb 20, 2019 | 10:48 AM
Sayvion Ralph
Supercharger has 113k on it and the new motor has 60k and no the supercharger wasn’t making that noise on the old engine and I have a stock pulley getting 10psi
Old Feb 20, 2019 | 10:58 AM
Racingguy04's Avatar
Racingguy04
I think it's either the supercharger or maybe the cam chain tensioner sticking. Might be worth replacing the tensioner, I think they're fairly cheap.
Old Feb 20, 2019 | 11:00 AM
IQRaceworks
Yep....I was thinking it sounded like a cam chain also. If you are getting boost, and no codes.....you might want to check out your chain tensioner first.
How many miles were on the motor when you installed it?
Old Feb 20, 2019 | 11:36 AM
Sayvion Ralph
I installed it 2 months ago 59k
Old Feb 20, 2019 | 11:55 AM
Sayvion Ralph
In the video that was a cold start it gets a little quieter when the car warms up but it is this noticeable that the car is making a sound
Old Feb 20, 2019 | 12:37 PM
cooper48's Avatar
cooper48
+1 on IQRaceworks ... chain tensioner first, then if that does not eliminate the sound, then I'm thinking chain guides (and maybe a new timing chain). Do you have a mechanic's stethoscope? They're cheap (less than $10, think Harbor Freight) and it's fairly easy to pinpoint a sound with one. Stick it on the timing chain cover and see what you hear.
Old Feb 21, 2019 | 02:58 AM
Sayvion Ralph
I just bought a mechanic's stethoscope the sound is the strongest at the supercharger
Old Feb 21, 2019 | 06:06 AM
cooper48's Avatar
cooper48
There are bearings, and self-contained oil chambers, at both ends of the supercharger. One chamber holds approx. 100ml (pulley end) and the other, 25ml. Normal service interval for SC oil changes is 100k miles so it's entirely possible yours has never been serviced (did you service it when you swapped engines?) and is running dry which can be catastrophic (and really expensive to replace). If it wasn't serviced, I would suggest pulling the SC and replacing the oil as soon as possible. If the noise is still occurring, then your SC bearings may be shot.
Old Feb 21, 2019 | 06:21 AM
Sayvion Ralph
Yes I serviced the supercharger when I put In the new engine I put 4.9oz in the front and 1.4oz in the rear. When I drained out the old oil there was plenty that came out of both sides
Old Feb 21, 2019 | 06:42 AM
Tgriffithjr's Avatar
Tgriffithjr
Which end of the SC is the sound coming from?
Old Feb 21, 2019 | 07:15 AM
Sayvion Ralph
Left side
Old Feb 21, 2019 | 08:12 AM
Tgriffithjr
By left I assume you mean drivers side. The water pump is on that side. You could be mistaking a bad water pump for the SC.
However the video seems to indicate the sound is from the passengers side. Sounds like timing chain related.
Old Feb 21, 2019 | 08:40 AM
Sayvion Ralph
It’s coming from the pulley side not the driver side passenger side
Old Feb 21, 2019 | 09:17 AM
cooper48's Avatar
cooper48
Any overheating issues, i.e., high temps, loss of coolant, etc.? That would certainly indicate the water pump. If not, then +1 with Tgriffithjr on the timing chain/guides/tensioner being bad, particularly if you've narrowed the location of the sound to the pulley side. Place your stethoscope onto the timing chain cover and check that out. Also, if it's a bad timing chain/guides/tensioner the sound should get quieter as you rev the engine (centrifugal force presses the timing chain more strongly against the guides and eliminates the slap/noise).
Old Feb 21, 2019 | 09:23 AM
Sayvion Ralph
When I rev the engine the sound gets louder and faster. When I put my sthethscope on the valve cover I don’t hear anything. When I put it on the supercharger horn I hear the noise a lot on the pulley side. No my car is not overheating at all.
Old Feb 21, 2019 | 09:28 AM
Tgriffithjr
Put the scope on the timing chain cover closer to the fire wall not on the valve cover. The tensioner runs vertically on the front rear of the engine.
Old Feb 21, 2019 | 09:29 AM
cooper48's Avatar
cooper48
Sounds as if the timing chain/guides/tensioner are bad. If it was me I would replace as soon as possible. Your largest threat with a bad chain is the engine jumping timing and that could cause a valve to hit a piston providing you with a large, heavy paperweight.
