R50/53 No fuel
Old Feb 16, 2019 | 06:44 PM
Birdinwy's Avatar
Birdinwy
No fuel
I have a late 2003 r50 not getting fuel checked the relay and it's good power to fuel pump good, new fuel pump and filter, no fuel to rail. I have spark what else could I check? Will the crank sensor still produce spark with no fuel? I'm at a loss and could use suggestions. Thanks
Old Feb 16, 2019 | 07:13 PM
Tgriffithjr's Avatar
Tgriffithjr
What does your fuel gauge read?
Old Feb 17, 2019 | 07:18 AM
cooper48's Avatar
cooper48
Pull the fuel pump once again and check to ensure that the top is fully seated (above the filter). If this is not sealed properly, your car will not start.
Old Feb 17, 2019 | 10:20 AM
Birdinwy's Avatar
Birdinwy
Thanks for the replies the fuel gauge is reading just under 3/4 and I will double check the filter
Old Feb 17, 2019 | 03:46 PM
Birdinwy's Avatar
Birdinwy
Ok filter is in correct still no fuel to rail. I have checked power through the fuel shut off and it does I have power through the fuel relay and to the fuel pump what other sensors can I check to see if the are bad and not letting the fuel pump turn on
Old Feb 17, 2019 | 04:06 PM
cooper48's Avatar
cooper48
There's a Schrader valve (like on an inner tube) located at the end of the fuel rail (underneath the back of the supercharger). Have someone crank the car while holding a rag against that valve (push the needle in with a screwdriver) and see if you have fuel pressure. If you do, it will squirt out pretty quickly. If there is no spray, then you're not getting fuel to the rail. With the bottom of your back seat out, can you hear the fuel pump prime when turning your ignition to position 1? If not, your fuel pump is not operational. I'm still betting that since you changed the filter, the top fuel filter housing is not fully seated. I did exactly that on my R53 (took it out and put it back it three times thinking I had it seated) before discovering that I just wasn't installing the top correctly. As soon as I had it fully in position, it started right up.
AnyMiniMineyMo
May 28, 2007 10:40 PM
bolar
Mar 20, 2006 09:52 AM
MyMini05
52
May 24, 2005 07:55 PM
Nomios_SLC
Feb 21, 2005 07:22 PM
