R50/53 Identifying heated seats from a 2004
Old Feb 7, 2019 | 06:38 PM
WheelNut's Avatar
WheelNut
Hey Everybody,
I have a 2004 R53 I’m parting out (it was included in the deal with my ‘05 R53) and I suspect the seats might be heated, but I can’t tell. The seat heater/mirror control panel is missing. The seats do have three connectors on them unlike the two connectors on the seats in my ‘05. The plugs are one yellow, one blue, and one black (4 pin).
I might swap them into my ‘05 since they are in a bit better shape, but I’m not sure if I’m bothered to deal with the wiring. I live in Vancouver now, so its not terribly cold here and thr heated seats aren’t something I dearly need.
Thanks in advance,
Brad
Old Feb 10, 2019 | 12:05 PM
maxw's Avatar
maxw
I believe a 2004 driver seat with the heating element installed will show 4 items connected underneath:
  • Yellow - seat airbag
  • Blue - seat belt pretensioner
  • Black (1) - seat belt latch? (I'm not certain about this one)
  • Black (2) - heated seat - this is a larger plug with a thicker gauge wire
Additionally - not applicable on a 2004, but starting 2005 the passenger side seats have a 5th connection for the seat occupancy sensor (to turn off passenger side airbag if not occupied...at least on US spec cars).
Also, I've read here that many 2004's and earlier that didn't have heated seats installed as an option from the factory still had the heating element in the seats - but did not have the wiring to connect them (or operational switch). There was speculation that Mini did not order enough unheated seats, or had a supplier shortage, so often put in the heated seats regardless. So if someone has a 2004 or earlier without the heated seat switch on the side mirror controls, they can check and see if they have a free/open connection under the seat. If they do have an additional plug without anything connected, it should mean they have the heated seats (and just need to add the wiring and switch).
In my case, my 2004 did not have heat installed at the factory nor did it have the heating elements in the seats. I replaced my 2004 seats with 2005 seats (panther leather), and installed the wiring retrofit kit to take advantage of the heating element that was in the "new" 2005 seats.
It was a project getting the wiring done, but I'd say it was totally worth it. The heated seats have been a nice addition...and I don't live in a cold climate either...just nice to have on the days when it is chilly out.
To be 100% sure on this for your application, I'd suggest removing the 2004 seats from the car - it'll help confirm exactly what you have. I'm betting you'll see the yellow for the airbag (going up in to the seat) and the blue and black going to the seat belt latch/pretensioner.
ti22fjc
Aug 11, 2022 01:31 PM
patsum
General Mini related Ads
Sep 29, 2013 04:06 PM
mp5999
Aug 26, 2013 06:20 PM
patsum
Jul 26, 2013 07:40 AM
CRRIKEY
Jan 4, 2008 07:14 AM
