R50/53 Rear camber links
Old Feb 7, 2019 | 04:10 PM
jk6672's Avatar
jk6672
Rear camber links
I started disassembling the rear to install the PowerFlex rear trailing arm bushings along with sway bar, coil over and H sport camber links. I didn’t realize there is an upper and lower OEM link and I only have one pair of H sport links, should I install upper and lower camber links?
Old Feb 7, 2019 | 04:43 PM
Zsm's Avatar
Zsm
You really only need lowers for a primarily street driven car.
Old Feb 8, 2019 | 04:58 AM
v10climber's Avatar
v10climber
This. Having adjustable upper and lower links isn't really necessary. Just replace the lowers and you'll be fine.
Old Feb 8, 2019 | 08:02 AM
jk6672's Avatar
jk6672
Thanks. I’m curious why, other than I see there is some kind of sensor attached to the upper left side that wouldn’t be able to attach to an adjustable. Does anyone know what that sensor is?
Old Feb 8, 2019 | 08:21 AM
SupeR53's Avatar
SupeR53
That sensor runs to your DSC and tells it how much your rear suspension is extended or compressed via an algorithm.
StettlerArsenal
May 5, 2015 11:38 PM
Mjimport
Feb 10, 2013 07:55 PM
dominicminicoopers
Suspension
Jul 1, 2005 03:43 PM
