R50/53 Clutch won’t engage
Old Feb 6, 2019 | 08:21 AM
William lee Schmidt's Avatar
William lee Schmidt
Clutch won’t engage
I have an 04 r53 I’m having some issues. Tried searching but couldn’t find anything. Got the car off of a guy for $1000. He said after replacing the brakes he was driving down the highway and it just stopped going. I’ve tried putting it in every gear but when I release the clutch it won’t move or stall or anything. Could this be the clutch or the slave cylinder might have air in it? I’m totally lost on this one.
Old Feb 6, 2019 | 08:37 AM
Apexlate's Avatar
Apexlate
Slave cylinder would be the first thing I'd check cause it's the cheapest bit to fix.
Old Feb 6, 2019 | 10:05 AM
IQRaceworks's Avatar
IQRaceworks
The slave cylinder disengages the clutch.........it doesn't engage it. If you have air in the system, or a bad slave cylinder...when you press the clutch pedal to the floor, noting happens....it's like you are not pushing the pedal in...i.e, the clutch stays engaged.
When you bought the car did it have this problem? Sounds like you are going to need to replace the clutch.
Old Feb 6, 2019 | 10:31 AM
JAB 67's Avatar
JAB 67
With the car clearly in gear, and your foot off the clutch, and with your foot on the gas does the engine increase speed but it goes nowhere? Then yes, probably a broken clutch pressure plate.
Old Feb 6, 2019 | 01:59 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
....or your shift linkage is broken and you're in neutral. Can you feel the shifter going into a gear?
Old Feb 6, 2019 | 03:18 PM
William lee Schmidt
Yea it’s going into gear I can feel it and hear it. I’m pretty sure it’s the clutch. How difficult is it to change? I’m pretty mechanical as I’ve done a few engine and transmission swaps and stuff but never worked on a mini. Also how long does it take to drop change clutch and reinstall the transmission?
Old Feb 6, 2019 | 05:04 PM
jk6672's Avatar
jk6672
It's not that bad of a job if you are mechanical and have the tools. If you're not going to pull the engine for the job get the strut tower engine brace to support the engine from the top. I just did the clutch and installed a LSD while I was at it. Watch the MOD mini video on YouTube. That's what I did before proceeding. I also made some long guide bolts for reinstalling the transmission, which made for aligning the transmission to the engine to re-butt it a breeze.
Old Feb 6, 2019 | 07:18 PM
William lee Schmidt
Is it easier to pull the motor and tranny all at once or is it more of a pain?
Old Feb 6, 2019 | 07:25 PM
jk6672's Avatar
jk6672
They say it's easier, but I didn't find this way difficult. here's the guides I used that made it a breeze:
Old Feb 6, 2019 | 07:38 PM
IQRaceworks
It's easier to just pull the tranny. Not a super hard job.....just takes a lot of time. It makes it much easier if you have a big floor jack and/or engine hoist to help support things when you pull the transmission off of the motor.
​​​​​​ Take pictures as you go, it makes getting everything back to where its supposed to go easier. Lots of how-tos on the forums (I think I even did one).
TurboMeTroy
Jun 30, 2016 12:42 PM
Al T
Feb 15, 2014 11:23 AM
dewitte
May 25, 2011 10:44 PM
uncledread
May 10, 2011 07:55 PM
justaguyinvegas
Jan 23, 2007 05:24 AM
