R50/53 R53 pulley question
R53 pulley question
I bought a 2006 r53 (60k miles) this fall and had a low compression issue in cylinder 4 after leaving the dealership. I took it back and they claimed to fix it. It is better but is not perfect (was140,140,140,80, now 140,140,140,130). Would you still consider it safe to do a reduced pulley on the supercharger?
How did you initially determine the low compression? What did they say they did to increase compression 50 lb.? Did they perform the compression test properly with a warm engine, throttle fully open, all plugs out?
I had a misfire in cylinder 4. I took one plug out at a time and screwed a compression tester into each cylinder. I removed the fuel pump fuse and cranked for 10-20 seconds. Did I do it incorrect. They claimed the computer told them compression was good. However the mini dealer said the computer doesn't tell you compression .they claimed it was faulty spark plugs and wires and they changed them, they did not. Im guessing they dumped some cleaner or gasket sealer.
The only way "they" could've quickly increased compression was to have squirted oil down into the affected cylinder. If you did the compression test, then do it again with a warm, not hot, engine, pull all four plugs and the fuel pump fuse, accelerator to the floor, crank until needle stops rising. Be sure your compression tester has a good O-ring seal and that you make sure it's fully seated each time you test. Do the suspect cylinder first this time. Let us know what readings you get.
Julien
Aug 4, 2017 10:58 AM
Drivetrain R53 Pulley/CAI/BPV question
speedracer1600
May 10, 2016 06:40 PM
C-Lop
Mar 24, 2010 12:05 PM
efcmini
Aug 31, 2003 09:48 PM
