Hard to warm up cabin
Old Jan 20, 2019 | 10:31 AM
torque124's Avatar
torque124
Hi all,
This is my first mini; I have a 2012 R56 manual... I noticed now with cool temps in New England that she is very hard to warm up; my wife complains that the cabin is cold for a long time when driving.
I just did a test today, and she is right. Even after idling for about 7-8 minutes, the air was not warm coming in the cabin, very very slightly warm... My BMW 335i warmed up in 5 min, you could sit in it like in a sauna.
Is the thermostat known to fail (53k miles) early in life ? I think the water pump is new (previous owner had it replaced under some recall), but I am not sure they changed the thermostat. The coolant level is fine, over minimum.
Thanks all.
Old Jan 20, 2019 | 10:42 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I've driven/owned/leased three MINIs to date. The heating & cooling system is awful IMO. No other brand of car has ever confounded me so much on getting heat.
You really shouldn't sit and idle the car for 5-8 minutes. It is meant to be driven slowly pretty soon after start up. This true for cars that no longer use carburetors. https://www.popularmechanics.com/car...-harms-engine/
I've found that if I change the temperatures and settings when I first get going it kicks the system in the rear and it starts to work. Play around with manual vs. auto settings as well.
Beyond that, you could have other issues as you mention.
Old Jan 20, 2019 | 01:30 PM
Minidogger's Avatar
Minidogger
Same complaint
I use sport mode for higher RPMs & also run defrost initially - that runs A/C compressor & puts extra load on engine.
Old Jan 20, 2019 | 03:55 PM
GH05TB34RD's Avatar
GH05TB34RD
Originally Posted by torque124
Hi all,
Thanks all.
lad to see I’m not the only one. New England as well, new R56 owner. Wonder how I’m going to deal w frosty windows.
Old Jan 20, 2019 | 04:17 PM
Minidogger's Avatar
Minidogger
There's always the redneck thermostat enhancer - - cardboard in front of the radiator!
Old Jan 20, 2019 | 04:34 PM
AZdsrt's Avatar
AZdsrt
One of 3 things. Air in the coolant, coolant low or the thermostat is stuck open. Coolant low is the easiest to check, if full then open the purge air valve (lots a threads on how to do that). If no love, look into replacing the thermostat housing which is a known problem on this auto.
minnimal
14
May 31, 2023 09:45 AM
jokerswild
Nov 2, 2018 05:33 PM
Smitha6
12
Apr 21, 2016 09:12 AM
Sperry50
22
Jan 14, 2012 05:37 PM
XAlfa
Cooper (non S)
Aug 8, 2003 09:47 AM
