R53 potential head gasket issue
Old Jan 6, 2019 | 04:53 PM
Black Forest's Avatar
Black Forest
Hello
Im working on a friends R53 that was loosing coolant and overheated. I have good compression, no signs of the traditional white smoke out the tailpipe but a fair amount of coolant in the oil. Coolant shows no signs of oil intrusion but as mentioned oil definitely does. I use to work on quit a few euro cars with heat exchange oil coolers but in my experience if the cooler goes bad its usually the oil that gets mixed in the cooling system. Looking to see if anyone here had been down this road before tear down. Thanks all.
Old Jan 7, 2019 | 05:47 PM
Tgriffithjr's Avatar
Tgriffithjr
Head gasket failure.
Old Jan 7, 2019 | 05:52 PM
AoxoMoxoA's Avatar
AoxoMoxoA
Originally Posted by Black Forest
...I use to work on quit a few euro cars with heat exchange oil coolers but in my experience if the cooler goes bad its usually the oil that gets mixed in the cooling system...
Correct. I had a cooler failure on my R53 which was discovered as oil in my coolant. If you're interested in reading up on it, the thread is HERE.
In your case unfortunately, it looks like the head gasket has failed.
Old Jan 8, 2019 | 08:55 AM
Black Forest
Thank you for your input. I kind of figured but thought I had better check in before proceeding. Will update
CSP
May 15, 2017 11:36 AM
R56typeS
Sep 16, 2013 06:51 PM
jhiggs26
Aug 26, 2013 04:56 PM
R53Warrior
Mar 8, 2010 04:03 PM
SharoSC02
Feb 4, 2007 11:13 AM
