R50/53 2005 Mini Cooper S crank, no start???
Old Jan 5, 2019 | 02:23 PM
Rob Dav's Avatar
Rob Dav
Recently bought 2005 Mini Cooper s. Bought used with 119,000. Ran fine for a month then went to leave work one day and wouldn’t fire up. Engine cranks but won’t start. I changed crankshaft position sensor and still nothing.... any help would be appreciated
Old Jan 5, 2019 | 04:35 PM
cooper48's Avatar
cooper48
Wow, could be a hundred things. Might be a weak battery - have that tested at an auto parts store. Then you should check spark at the plug while cranking (pull the plug wire from the coil, stick a screwdriver into the end and hold close to a metal component). Don't touch the metal part of the screwdriver unless you're looking for a wake-up call. When cranking, a spark should arc between the screwdriver and the metal part. No spark - might need to replace the coil. If spark, I would look at fuel system delivery, i.e., check pressure at the fuel rail. If no pressure, I would then look to the fuel pump (under the rear seat - passenger side).
pkakaie
Mar 4, 2018 01:05 PM
Climb138
Dec 6, 2013 08:18 PM
ericmakkar
May 20, 2011 05:16 PM
mdsbrain
Mar 1, 2006 06:45 AM
