Interior/Exterior Problem with Sneed Billy Club Install
Old Dec 27, 2018 | 06:06 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
I'm posting here and in "Drivetrain" in hopes someone can offer a solution. Instructions are to heat it in hot water so I put that sucker in a pan of hot water on top of the stove to heat it up...Still couldn't even get it started on the shifter shaft. Tried hitting it with a rubber mallet...No help. Really afraid that, if I got it on, I'd never get it off. What am I missing here? This isn't "Rocket science"!
Old Dec 27, 2018 | 08:24 AM
vetsvette's Avatar
vetsvette
Moderator
I had to heat mine in boiling water and tapped it on with a small ball peen hammer. When I replaced it with a billet aluminum S4S **** I had to cut the delrin version off. The billet versions use set screws to mount. If you have a CravenSpeed adjustable Short Shifter you can use a threaded version. IIRC on my R56 with the CS shifter I used the **** made for a Mustang. Bottom line, if you use the press fit,... if you have plans to remove and sell at a later date, fuggedaboutit!
Old Dec 27, 2018 | 09:02 AM
NC TRACKRAT
Veteran: Navy
Thanks for the info., vetsvette...suspicions confirmed. I think I may resort to reaming out the hole a few thousandths to make this a snug fit but not "permanent".
Old Dec 27, 2018 | 11:55 AM
ThumpR52's Avatar
ThumpR52
Old Dec 27, 2018 | 01:06 PM
NC TRACKRAT
Veteran: Navy
Thumper, that's just about the size of it!
Old Dec 28, 2018 | 01:52 PM
NC TRACKRAT
Veteran: Navy
Just heard from Sneed. Apparently, some Billy Clubs were drilled with the wrong size hole. Replacement on the way.
Old Dec 28, 2018 | 03:41 PM
vetsvette's Avatar
vetsvette
Moderator
Good to hear. In my experience Chris has always been easy to deal with.
NC TRACKRAT
Dec 26, 2018 01:40 PM
DrFraserCrane
Jan 27, 2015 09:38 AM
P4pumpman
Oct 24, 2013 04:53 PM
SneedSpeed
How to
Apr 11, 2012 12:41 PM
