Mini/MINI BUILDS Showcase your Build Talents.
Dirt Cheap '04 S
Old Dec 25, 2018 | 06:55 PM
rhenry01's Avatar
rhenry01
Dirt Cheap '04 S
I was out with a friend who was looking for a used, low-priced pick-up truck to use as a daily driver. We went to see another friend of ours in the used car business. While we were all shooting the breeze I told our sales friend I might be in the market for a MCS that I could pick up on the cheap as a fix'er up'er. Two days later I get a call from the friend and he tells me he just took in an '04 MCS on trade and it's just what I'm looking for. He gave me a run-down on what might be wrong with it.He told me how much money he had in the car and told me I could have it for that. WOW! I couldn't believe what I heard, I had enough money to buy the thing in my wallet!
I got to the lot not expecting much but again I was surprised at the overall condition of the car. Some minor imperfection in the paint, driver's seat that is cracked on the bolsters and it needed a good cleaning. For the price I was paying I know I can haul it to the local Pull-A-Part and make money so I forked over the cash.
So the problems are:
Overheating (top radiator hose doesn't get hot)
Squeaking when the wheels turn (strut mounts are toast)
Oil leak (looks like a rear main seal)
Rock peck in the windscreen (who cares)
Driver's door does not unlock with the remote (but I can hear the mechanism moving)
Tires have tons of tread but are cheap Chinese crap and one has separating belts (they need to go)
Good Points:Engine starts and idles nicely
Clutch feels good
All the gears in the gear box are working
Interior is in really good shape
Has some performance part installed (underdrive pulley, Dinan Air box/filter)
No SELs
So here are the immediate plans. Check the water pump and replace if necessary, replace the thermostat, Change the crank angle sensor seal, drop the oil pan to see if the rear main seal is bad and replace the oil pan gasket. Replace the rear main seal if it needs it. Replace the accessory belt and get some new non-run-flat tires. Think up a name for the car ..... "Lemon Bomb" comes to mind......
This isn't my daily driver so I don't have any specific plans for the car yet but I think I'll be using it more for track day and autocross than commutes to work. We'll see how it goes.
So here are a couple pictures.
Old Dec 27, 2018 | 03:18 PM
rhenry01's Avatar
rhenry01
So I cleaned up a bay in the garage and pulled the Mini in. I watched a couple YouTube videos and I'm ready to take a closer look at the water pump. I follow the instructions to put the car in front end service mode. While I'm taking things apart I get a closer look at the bottom of the car. The car has lived it life in the south so there isn't a speck of rust on the underside of the car, WIN! I did get a closer look at the oil leak and it is coming from the passenger side of the engine up at the top of the oil pan gasket. Since it looks to be a heck of a lot easier to change the oil pan gasket than the rear main seal I'm going to try that first. I Googled the part number on the supercharger pulley and it turns out that it is a Dinan piece also. The car has been worked on before because whoever did the servicing didn't put the crush tube front bolts back in. I didn't have any long 8MX1.25 bolts to extend the front end on to so I quit there. Next step is to remove the supercharger to get a good look at the water pump. I figure I'll do an SC oil change while I have the thing off. The Pelican Parts shopping list is starting to grow.
- Strut Mounts
- Crank Sensor O Ring
- Oil Pan Gasket
- Supercharger oil
- Thermostat
- Accessory drive belt
- Various hoses
- Water Pump (maybe)
Old Dec 27, 2018 | 04:06 PM
ThumpR52's Avatar
ThumpR52
You don't need to take the SC out to remove the water pump.
1.) Put in Front Service Mode
2.) Do not disconnect AC Condenser, swing to side and support so you cannot kick it.
3.) Pull radiator
4.) Remove the supercharger horn above the throttle body by loosening the clamps at the BPV.
5.) There are two bolts that hold the 2nd Part of the Water Pump to the block, remove these first. You may need a flashlight to see them.
6.) Now remove the water pump.
7.) Be careful of the tubes leading out of the black plastic airduct running from the throttle body to the SC.
Now depending on the miles you may want to remove the SC anyways so you can check the oil.
Oh, and nice looking Gen1.
Old Dec 27, 2018 | 06:42 PM
rhenry01's Avatar
rhenry01
3.) Pull radiator
Thanks for the info. I want to pull the SC to do the oil change as I don't know when the last real service was done on the car.
Old Dec 27, 2018 | 06:58 PM
rhenry01's Avatar
rhenry01
I got very little work done on the car this evening before life caught up with me. I did manage to take a few pics of the Dinan parts and my organization method. I learned a long time ago not to rely on my memory when it comes to what parts go to what. So now I bag and tag everything I can. If I can't put a bolt back into the boss that it goes into I put it in a baggie and label it with a sharpie. This is a lifesaver when it come to projects that take more than an evening. So here it is, I cut an X in the box with a hobby knife and stick the sharpie in it so it's always where I need it.
And a labeled bag:
Here are the Dinan parts:
Old Dec 28, 2018 | 06:47 PM
rhenry01's Avatar
rhenry01
Worked for a few hours on the car. Pulled the intercooler, the radiator the intake and started on the water pump. Every piece has been a pain to work on. Every hose clamp has been in exactly the wrong position and even the dip stick tube wouldn't clear the supercharger housing, the two tubes on the back of the supercharger intake tube wouldn't pop out. I just stuck with it and tackled each problem. I also spent about twenty minutes looking for a forth bolt on the water pump ...... it doesn't exist (unless I'm crazy,) every video I watched said there are 4 bolts. That's were I left off. I'll try to get back to it tomorrow but the WRX needs attention so I'll be working on that.
One thing I did notice is that the throttlebody is a Dinan piece. Did all these Dinan parts come stock on the car or did the previous owner put them on? I'm wondering if the car has a tune on it, did Dinan make an ECU/tuner? Did you have to send the ECU off for a tune?
Here is a pic of the throttlebody:
Old Dec 29, 2018 | 09:21 PM
rhenry01's Avatar
rhenry01
With the upper radiator hose disconnected from the water pump I could look into the pump and see the impeller. I rotated the supercharger pulley while looking at the impeller and the impeller didn't move. I stuck a screwdriver into the water pump and rotated the impeller, it rotated too easily and the supercharger pulley didn't rotate. At this point I think the water pump is shot. Tomorrow I'll get the water pump pulled off, confirm the thing is bad and order a replacement. I hope this is all the mechanical problems sorted out, if so all I need is a new set of tires to get on the road for test drive.
I was looking in my parts cabinet and ran across some VDO gauges and adapters off of my '93 Nissan SER. I'll figure out a place to put them in the mini when I get the time.
Old Dec 30, 2018 | 10:26 AM
rhenry01's Avatar
rhenry01
NNNNNNNNNOOOOOOOoooooooooo!!!!!!!!!!!!
My unheard-of Super Awesome Steal of a Deal just got downgraded to a Really-Really-Good deal. The PTO that drives the water pump is shot. So I have to get the supercharger rebuilt. Has anyone dealt with AutoXCooper or Stigmeier Porting?
Old Dec 30, 2018 | 02:35 PM
ThumpR52's Avatar
ThumpR52
Could go with a rebuilt, AutoXCooper was noted in a another recent post as they were doing some warranty work of a unit they rebuilt, or, you could try a used unit from either a yard, ebay or even a You Pull-it place.
So how much did you pay for the car?
You can tell us as will not tell your wife . . . . . . .
Old Dec 30, 2018 | 04:05 PM
rhenry01's Avatar
rhenry01
Yea, I thought about a used unit from somewhere but since I'm going to be keeping it I want the peace of mind. AutoXCooper offers a 2 year unlimited mile warranty (implied quality?) and I want to keep this level of repair to a minimum. I paid $618 for the car all-in knowing that it was a pig in a poke but I wasn't expecting a supercharger rebuild, maybe a short block with the overheating. So while I'm waiting for the supercharger I'll tidy up the interior and paint. I've got a bunch of plastic clips coming in to replace broken/missing ones and I have a huge order for hoses, belt and seals that should keep me busy for a while.
Old Dec 31, 2018 | 08:35 AM
Nice find with the dinan stuff, all i can think of is go with the JCW superchager, it on sale and we have them in stock. It comes with the JCW pulley so you can keep that or just swap to the other pulley. So it also has the updated Teflon coated rotors.
Then you just need the correct serpentine belt for your set up. If you decide to go this route otherwise you have the rebuild.
https://www.ecstuning.com/b-genuine-...w/11657556981/
Keep up the great work like seeing this rebuild. On my R52 i finally just replaced the A/C compressor at 283K. Dang thing locked up solid with rust.
Old Dec 31, 2018 | 06:47 PM
rhenry01's Avatar
rhenry01
I'll be calling sales on the 2nd to get more info. Thanks!!
Old Jan 2, 2019 | 06:43 AM
You are welcome.
Old Jan 6, 2019 | 02:38 PM
rhenry01's Avatar
rhenry01
AutoXCooper.com and ECSTuning.com to the rescue!
I want to give a shout out to AutoXCooper.com, I emailed them and I spoke to Dustin about the many options I had when rebuilding/replacing my supercharger. Dustin was very straight forward with his recommendation, which was to buy a new supercharger (given the price I could get one at) rather than rebuild my existing unit. If I were going to race the MINI full time or if the cost of the supercharger wasn't where it was at I would have had Dustin rebuild it. It isn't very often that someone in a business will tell you not to buy their product, that says a lot about Dustin and AutoXCooper.com! That being said, I placed an order for the new supercharger with ECSTuning. I have been recovering form a terrible cold this week but as soon as I do some more work on the car I'll post up some pictures.Let the fun continue!!
Old Jan 7, 2019 | 06:21 PM
rhenry01's Avatar
rhenry01
10 pounds of crud
Man, a couple years of neglecting oil leaks and you get about a pound of oily crud built up on the front of the engine.I scrubbed at it with Simple Green, Scrubbing Bubbles and warm soapy water, none of them were working well. I broke out a set of plastic scrappers and started scraping the bulk of the crud off and then I went out and bought a can of Gunk engine degreaser ..... that did the trick! The Gunk cut right through the crud and I helped it out by scrubbing the crud off various stiff bristle brushes. The front of the engine is now acceptable and I can get on with the oil pan gasket replacement.
Old Jan 7, 2019 | 06:32 PM
valvashon's Avatar
valvashon
This is probably the door lock actuator. These will fail and fool you- they still make noise but don't actually have enough power to lock or unlock, whatever it is trying to do. Get a new one from MINI, the replacement ones are better built than the OEM ones. This isn't the place to cheap out and get a used one.
I don't work on the actuators (although there are some how-to-fix-them threads out there) but I do work on keys- what shape are they in?
Val
Old Jan 8, 2019 | 05:28 AM
Yep, Talks about it here: https://www.northamericanmotoring.co...-t-unlock.html
I had mine do this like it was weak on the actuator.
Old Jan 8, 2019 | 06:02 AM
cooper48's Avatar
cooper48
While you have it torn down, I recommend that you also replace the front engine seal (behind the crankshaft pulley). It's a common oil leak on MINIs. See YouTube for ModMini who details an easy way to remove it using a screw. Replacement is easy and cheap.
Old Jan 8, 2019 | 08:15 PM
rhenry01's Avatar
rhenry01
Thanks for the recommendations, I'll look into it.
Old Jan 9, 2019 | 06:27 PM
rhenry01's Avatar
rhenry01
New Part Goodness!!
Got a package from ECS Tuning!! Ordered Sunday Evening, arrived early on Wednesday.
Old Jan 10, 2019 | 05:45 AM
Awesome, here comes that SC whine.
Old Jan 10, 2019 | 11:41 AM
aunknown's Avatar
aunknown
That's sexy!
Old Jan 10, 2019 | 06:00 PM
dmath's Avatar
dmath
Congratulations! Good looking car and a lot of fun projects. Great score on the new supercharger.
Have you considered white covers for the rally lights, to match the mirror covers and roof?
Old Jan 10, 2019 | 07:04 PM
rhenry01's Avatar
rhenry01
Didn't even think about it but you are right. If I run across a pair in the u-pull-it yard I'll snag them.
Old Jan 15, 2019 | 04:06 PM
rhenry01's Avatar
rhenry01
TDC - No, not top-dead-center!
TDC - Too Damn Cold! it's in the 30's and it's just TDC to work in an unheated garage. I think later in the week it's supposed to warm up a bit.
