Sunroof switch loose
Old Dec 21, 2018 | 01:40 PM
Camber13's Avatar
Camber13
2011 Countryman S. My wife noticed the sunroof was balky, when I looked the overhead switch is quite loose. Switch works fine to open and close, but is very loose in the assembly. Suggestions? I'm assuming you just pop the plastic cover off the overhead switch assemblies to get access?
thanks for any assistance!
Old Mar 25, 2023 | 10:58 AM
cjv2's Avatar
cjv2
A bit late to respond but for anyone else running into this issue, this or similar is likely what you have going on. Not repairable in the case of mu F56; the whole switch assembly has to be replaced. Different assemblies depending on vehicle options so make sure you get the right one for your car. But as you note, continues to work electrically.
cjv2
Mar 25, 2023 01:42 PM
Camber13
Dec 30, 2018 08:22 AM
donniedarko
R55 :: Clubman Talk (2008+)
Nov 13, 2017 08:41 AM
Blackbomber
Jun 29, 2011 04:43 PM
