R50/53 R53 440cc injector better select!
Old Dec 19, 2018 | 11:45 PM
emo's Avatar
emo
I want to know the best select of 440 cc injector.
Old Dec 21, 2018 | 10:20 AM
IQRaceworks's Avatar
IQRaceworks
What mods are currently done to your car? Are do you have someone lined up to tune it in order to make it run with the larger injectors?
Old Dec 22, 2018 | 06:54 AM
emo's Avatar
emo
Thank You
Now it's a stock engine
The header is flushing the stock to fit the exhaust port. The catalyst was removed.
borua muffler.
7600 rpm with stock pulley
Either way, we plan to form 15%.
I use FA53.I am considering using BOSCH 968 440 cc.
Old Dec 22, 2018 | 07:00 AM
IQRaceworks
With just an exhaust and pulley.....not sure larger injectors are going to gain you anything. If you are able to dial in the A/F ratios you need with your current injectors.....what are the 440's going to get you?
Old Dec 25, 2018 | 03:42 AM
emo's Avatar
emo
Do you know 440cc injector?
Both are 15% assembled
It is because I do not intend to use it over 90% duty cycle. Do you think that it is enough to add wall correction and intake air temperature correction?
I do not need it unless I run a truck, but I need it.
Do you know 440cc recommended injectors? I am not questioning to satisfy your interests.
Old Dec 25, 2018 | 05:24 AM
IQRaceworks
What????
Old Dec 25, 2018 | 10:51 AM
RB-MINI's Avatar
RB-MINI
Looks like an English translator is being used and is not working very well. Seems like he’s looking for recommendations on 440’s for more headroom because he doesn’t want to run the stock or JCW injectors close to the limit.
Old Dec 25, 2018 | 12:38 PM
IQRaceworks
He's not going to run JCW injectors OR even the stock S injectors to the limit with just a pulley and exhaust.
D-MAN
Nov 5, 2010 12:34 PM
cozyp828
Sep 12, 2010 06:21 PM
RIPPER
26
Feb 21, 2008 08:33 PM
Minirowski
Jan 26, 2006 11:22 AM
