R50/53 2006 R53 passenger door lock
Old Dec 14, 2018 | 04:42 PM
Jagermeister956's Avatar
Jagermeister956
My R53 has an intermittent door lock issue..Sometimes the passenger door works great ..other times it does not and I can't open the door..The key/dash toggle/doors lock when driving/door lock button comes up/ the drivers door works perfectly...everything works..Can anybody shed some light as to what dark forces may be at work here?.
Old Dec 15, 2018 | 06:03 PM
Tgriffithjr's Avatar
Tgriffithjr
The cable is probably coming loose and will eventually not work at all. There’s a thread on here about how to fix it. It is a recent thread so it’s probably still visible.
Old Dec 16, 2018 | 09:40 AM
Jagermeister956
Thanks for the reply...I'll try looking at the cable...My problem now is I can't open the door from the inside or by the exterior handle...as I said in my previous post everything works it's just the door will not open...I would imagine taking the door card off with the door closed is a real *****...I've done a search and found a couple of things to try so we will see how it goes...
Old Dec 22, 2018 | 09:54 AM
Jagermeister956
Finally got my door open by spraying some Corrosion X in the gap when the door lever is pulled in....
Old Dec 25, 2018 | 05:27 PM
wildwilly2004's Avatar
wildwilly2004
Which gap? Specifically where did you spray....I can not get my sons P side door open. Everything works with remote, but door will not open from inside or out :( Thanks
Old Dec 26, 2018 | 02:36 PM
Jagermeister956
Squeeze the handle and you will see this gap.....
This is the product I used....It works great...
Old Dec 26, 2018 | 03:51 PM
wildwilly2004
Thank you so much!!
Old Jan 20, 2019 | 09:13 PM
Mike Ross's Avatar
Mike Ross
I know this is a old thread but did this work for you as well to get your door open? My daughters driver side door wouldn't open from the inside and outside tonight when she came home from work
Old Jan 21, 2019 | 05:37 AM
wildwilly2004
It did not work for my son's. I had him take it to a mechanic. I do not know what he did, but it is working now.
Old Jan 21, 2019 | 07:42 AM
aunknown's Avatar
aunknown
I had a similar issue, turned out to be the lock actuator inside the door was going bad.
I ordered a used one from this site, been good ever since. Mine came with the cable like this one.
Old Jan 21, 2019 | 09:41 AM
MVPeters's Avatar
MVPeters
I'm not sure if this is entirely relevant, but on some cars, it takes two pulls of the passenger door handle to open the door.
Similarly if using the key fob, one press releases the drivers door only, two presses (or one long press) releases both doors, the gas cap & hatch.
I believe this varies among years & models; some of it is programmable.
Javskies
May 19, 2016 01:05 PM
spackletooms
Sep 1, 2015 10:12 PM
TimG
Jan 2, 2009 06:57 AM
cur
Mar 12, 2008 03:38 PM
