Code P2885
Old Dec 3, 2018 | 07:21 AM
drumband's Avatar
drumband
Code P2885
Hello all,
Recently i bought an 09 covertable with 176k car runs fine...........but sometimes when i run it very hard the engine light lights up inside the tachometer i looked it up P2885 it says something about turbo or boost pressure Like i said it runs fine and the light only come on when i run it very hard and when it does come on its not a hard stored code it lights up in the tach
Old Dec 3, 2018 | 09:59 AM
MrGrumpy's Avatar
MrGrumpy
Yep, that’s the dreaded P2885 code. Boost pressure deviation. There’s a few things that can cause this. Boost leak, bad diverter valve, turbo wastegate, and so on. Probably the first thing to do is check all of your charge pipes to be sure your not leaking somewhere. If that looks ok, check your diverter. Those are 2 fairly straight forward and not too hard to do things to check. It’s hopefully just your diverter, as they do fail eventually. The plastic bits inside can deteriorate and break. Pull it off the car and inspect it.
Also, it would help to know the exact condition that send it into limp mode or pops the code. For instance: does it happen on the highway, or under load, on a hill, speed, what you were doing at the time, etc this kind of info can really help sometimes. Like when I needed to replace my turbo, the symptoms were very specific under very specific circumstances when it would trip a code.
mini4tide
Nov 6, 2017 09:13 AM
SpuuDy
Dec 17, 2016 09:00 AM
Ladybug-S
Jul 10, 2015 02:23 PM
Black Sharpie
Apr 8, 2015 07:08 AM
Mini Coupe
Dec 31, 2010 07:01 AM
