Help! 08 clubman oil cap stipped
Old Dec 1, 2018 | 02:25 PM
Shane Jones's Avatar
Shane Jones
help cap just spins and will not come off. it spins both ways. it will get tight and then loose. does this turning left and right. can I add oil through the dip stick tube till I get this solve? thanks
Old Dec 1, 2018 | 02:45 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I see no issue with dipstick tube. Never had this happen, but if it was my cap I'd use a large vise grip plier and squeeze at the sides until I could get a grip on the inner part and turn. Probably break the plastic and then would need to replace the cap. Or just try prying the cap up and hopefully separate it from the metal part below. Then you could epoxy the plastic part back, or replace.
So it's finesse or force.
Old Dec 2, 2018 | 09:17 AM
MrGrumpy's Avatar
MrGrumpy
Force!!! Minnie.the.Moocher is probably right. You probably need to just grab that sucker with some channel-locks or something around the sides and make it come off, then replace it.
JaysinStrife
Jun 23, 2015 04:29 PM
WrenchMonkey
Suspension
Mar 9, 2015 08:52 AM
pimpedout97x
Sep 16, 2008 06:17 AM
Yucca Patrol
Sep 21, 2006 10:40 PM
MSFIT
Oct 18, 2005 09:41 PM
