DM computer
Old Nov 18, 2018 | 04:37 AM
Yoshimura 1's Avatar
Yoshimura 1
DM computer
I have a mini cooper S 2008 and i'm having a problem with the car starting.
The car cranks over fine has compression in all 4 cylinders, timining chain
looks good nothing broke or loose all guides are still intact. I have check
all the fuses in the fuse box in the engine compartment. All fuses have power
except fuses 2,3,4,5, has no power when checking with the test light. Fuses
1 thru 6 and beyond has power. My question is do these 4 fuses 2,3,4,5 get
power when the key fob is inserted get power. Do these fuses power the DM
or does the DM send a signal to power these while starting. The amps on these
fuses are 25amps- 20- 20-5 amps. The car also has a half tank of gas. I also checked
the relay for the DM i'm getting power to 2 contacts with the relay removed also checked
with the test light. what would send power to these fuses with no power?
gross67
97
Nov 13, 2011 03:01 PM
Chips-O'Toole
15
Nov 6, 2002 10:28 AM
