R50/53 help installing JCW airbox in R53
Old Nov 16, 2018 | 06:28 PM
Tobias Leung's Avatar
Tobias Leung
Hello,
I recently purchased a JCW airbox for my R53 and I have a few questions (in transit now). The electronic wiring may or may not come with it.
1) Do I need to hook up the electronics? Will the electronics even work if I don't have the ECU remapped? From reading this forum and others, seems like Mini wouldn't remap anyways, since I didn't buy the JCW tuning kit.
2) Do I install the vacuum hose if it doesn't come with the electronic wiring?
3) Do I just install it and don't hook up the vacuum hose?
Probably not the smartest purchase if I didn't figure out all of this before.
Thanks!
Old Nov 16, 2018 | 08:02 PM
co0p3r's Avatar
co0p3r
The jcw airbox is one of the best - so great choice.
I would tell you to just remove the flap inside and don’t worry about connecting the electric or vacuum- in the standard config these open up above a certain rpm (4500 if I remember correctly). If you remove the flap it breathes better all the time.
As to tune it it is not required the map sensor will sense the additional air and compensate. Later if you get some jcw injectors you can have the tune flashed on the ecu.
Old Nov 16, 2018 | 10:05 PM
RB-MINI's Avatar
RB-MINI
A lot of people with the JCW airbox disconnect the electronics and prop the flap open, or remove it altogether. The main reason for the flap was stricter noise restrictions in the UK.
Amsoil makes a great dry cone filter for the JCW: https://www.detroittuned.com/amsoil-jcw-air-filter/
Old Nov 17, 2018 | 09:54 AM
Tobias Leung
thanks for demystifying the process. I can't wait to get the new airbox installed!
Old Nov 19, 2018 | 04:38 PM
OCR's Avatar
OCR
Tobias -
I would NOT just prop the butterfly open (the "prop" could come out of position). It's a simple, 5 minute job to just remove it...no other work required. Save the fasteners and plastic butterfly for a later date.
I put my "extra" parts in a bag and tossed it into the glove box.
Mike
Black Forest
Feb 19, 2018 08:04 PM
MrBlah
Jun 7, 2016 11:04 AM
PhoR53
Apr 27, 2016 09:21 AM
replacement
Aug 19, 2015 08:46 AM
Whoosh
Cooper (non S)
Aug 23, 2010 03:18 PM
