I have a 30.00 OCC installed on the turbo side with BSH fittings. Will the BSH boost tap work fine with out having the BSH OCC. ECSTUNING is no longer selling the BSH fittings. So I was going to install the BSH boost tap instead of another OCC.
I have the BSH OCC on the turbo side and the boost tap/plug on the intake side and it works fine. There is now no vacuum on the intake side for pcv since it is blocked. Everything is sent through the OCC to the turbo. As long as you have a OCC on the turbo side, you should be able to block the intake side.
I have BSH Dual Boost Tap too, along with the BSH OCC. Just so I just understand, if I install the DBT as a plug behind the valve cover, there's no need to remove the PCV hose and put a plug down below by the throttle body (?) where the other end of the hose connects?
I bought a Generic OCC and it came with these fittings from a NAM seller. I dont need them as they look like R56 Parts (I have a R53). Will these help you?
I don't even know what those are for. Thanks though!
Thanks for the help.... I decided to tear everything out and walnut blast my intake valves and install a mishimoto OCC w/ a drain vavle on the intake side.
