Drivetrain BSH BOOST TAP with Amazon OCC
Old Nov 2, 2018 | 01:37 PM
redlinealley's Avatar
redlinealley
I have a 30.00 OCC installed on the turbo side with BSH fittings. Will the BSH boost tap work fine with out having the BSH OCC. ECSTUNING is no longer selling the BSH fittings. So I was going to install the BSH boost tap instead of another OCC.
Old Nov 7, 2018 | 08:50 AM
Purpleoctopus's Avatar
Purpleoctopus
I have the BSH OCC on the turbo side and the boost tap/plug on the intake side and it works fine. There is now no vacuum on the intake side for pcv since it is blocked. Everything is sent through the OCC to the turbo. As long as you have a OCC on the turbo side, you should be able to block the intake side.
Old Nov 8, 2018 | 09:58 AM
We just have the O rings and the full kits left.
Click HERE to shop the BSH
Old Nov 25, 2018 | 07:03 PM
Rixter's Avatar
Rixter
I have BSH Dual Boost Tap too, along with the BSH OCC. Just so I just understand, if I install the DBT as a plug behind the valve cover, there's no need to remove the PCV hose and put a plug down below by the throttle body (?) where the other end of the hose connects?
Old Nov 25, 2018 | 07:10 PM
co0p3r's Avatar
co0p3r
I bought a Generic OCC and it came with these fittings from a NAM seller. I dont need them as they look like R56 Parts (I have a R53). Will these help you?
Old Nov 25, 2018 | 07:51 PM
Rixter's Avatar
Rixter
I don't even know what those are for. Thanks though!
Old Nov 26, 2018 | 09:54 AM
redlinealley
Thanks for the help.... I decided to tear everything out and walnut blast my intake valves and install a mishimoto OCC w/ a drain vavle on the intake side.
samteezy
May 12, 2015 05:09 AM
TheCheatOSX
Nov 4, 2013 05:55 PM
BSH Speedshop
Jan 9, 2012 12:02 AM
matt376
Test Forum
May 15, 2006 08:44 PM
