Clubman Idles Fine but Upon Acceleration Stumbles and Not Driveable
Old Oct 31, 2018 | 11:29 AM
TNYWGN's Avatar
TNYWGN
Hello all. I am in need of some help. I have an 08 Clubman that is struggling to go down the road. It starts up fine and idles fine, but when you give it gas, the car stumbles and bucks and is virtually impossible to get above 5mph if that.
Here is what has been replaced on the vehicle.
Timing Chain Kit (ran fine after this for a while)
Air Flow Meter
Cam Position Sensor
Fuel Filter
Fuel tank drained completely and new fuel put in.
Valve Cover with PCV valve
I've run a fuel pressure test and am getting 50 psi at idle, so I do not think it is the High Pressure Fuel Pump. Could it maybe be the fuel pressure regulator? Am I missing anything else that I can try to help diagnose this problem?
Old Nov 1, 2018 | 10:48 AM
I like mini clubman's's Avatar
Im new here but have read a couple thousand posts LOL. Is the car throwning any codes? Im of the understanding that the hpfp is a much higher pressure Than 50 psi. That sounds like the pressure from the fuel tank pump.
Old Nov 1, 2018 | 11:14 AM
Yupetc's Avatar
Yupetc
HPFP pressure should be well above 700 psi. When I log my normal drive, mine's usually at 850-950 PSI. Also check your valves for carbon deposits, may need walnut cleaning if you haven't done it in a while.
Old Nov 1, 2018 | 11:46 AM
drea-min's Avatar
drea-min
My 08 Clubman S high pressure fuel pump at idle around 600-700, after walnut blasting i had problem it stumble during acceleration and like your car symptoms it idle fine, all coil pack are new prior to media blasting,
then it throws misfire code which i ignored i thought something else because i installed a Diverter valve spacer and i ended up taking it out but still it stumble, then i replaced the diverter valve itself due to detiorating on the diagphram but still stumble during accelerations. I finally look at the coil pack and when i pulled the #2 the rubber at the bottom seperated and installed the good coil pack that i removed and solved the issue, i can hear the new diverter valve functioning because this is the newer versions.
i suggest look at the coil pack and check for CEL or code.
Good Luck.
I also replaced the valve cover (aftermarket from WayMotors) not sure if the newer version with PCV and inspect the timing chain and guide they are tight and intact.
jetsr6
Mar 20, 2018 10:47 PM
s0udwrench
Jul 6, 2015 03:55 PM
berge1
Feb 25, 2015 08:53 AM
MNMLST
Aug 25, 2013 08:53 AM
Urohawk
Apr 17, 2012 11:24 AM
