Overheated 2010 base Mini Cooper
Old Oct 22, 2018 | 08:02 PM
Tao's Avatar
Tao
Hello everyone,
i have a Mini Cooper 2010 who had the engine overheated,I replaced the water pump and the pipe coolant.
i also removed the thermostat housing and it was melted,the valve cover also need to be changed.
since I didn’t performed a pressure test I don’t know if the head gasket and pistions rings are ok ?
what are the chances that I will need to remove the cylinder head and replace other parts ?
thank you.
Old Oct 24, 2018 | 11:42 AM
Tgriffithjr's Avatar
Tgriffithjr
Heck for coolant in oil; chocolate looking oil. Or oil in coolant. If no signs of either do a compression test.
Old Oct 24, 2018 | 04:30 PM
Tao's Avatar
Tao
Thank you for your response
I changed the thermostat housing but I can’t start the car it’s goes freak you can the see that on the video below
Old Oct 24, 2018 | 05:29 PM
Tgriffithjr
Check all your grounds. Battery good? That’s definitely an electrical problem.
bettehead
How to
31
Apr 11, 2024 10:47 AM
EMKFLYER
Dec 2, 2023 07:00 PM
Zommski
Jun 19, 2018 08:50 AM
ajstefanacci
May 10, 2017 06:21 PM
jbing
21
Jan 2, 2014 07:20 AM
