Starter will not come out
Old Oct 15, 2018 | 09:40 PM
Noahl's Avatar
Noahl
I have a 2007 mini and I have taken out the "2" screws mentioned and disconnected all the wires, but the dang thing will not budge. Am I missing a screw somewhere else? do I need to manually crank the motor to dislodge the starter teeth from the flywheel?
Old Oct 15, 2018 | 11:46 PM
Scudder44's Avatar
Scudder44
3 bolts on a Mini starter motor :-)
Old Oct 16, 2018 | 06:52 AM
MiniToBe's Avatar
MiniToBe
https://www.newtis.info/tisv2/a/en/r...unting/Q9ZPIat
Old Oct 16, 2018 | 08:11 AM
Noahl's Avatar
Noahl
And there it is... guess it makes sense with the lack of space on the design Thank you so much for the link and info to get this bugger out.
Old Oct 16, 2018 | 08:08 PM
oldbrokenwind's Avatar
oldbrokenwind
Also notice the guide pin / dowel / sleeve around one of the bolts. When putting it all back together, ensure this sleeve is mounted / inserted on the starter, not the block BEFORE bolting it back together. If you put this sleeve in the block first, it will go all the way in, and not engage the starter. This can cause the starter to not grab the flywheel when you try to start the car.
CRC
Nov 26, 2017 04:46 AM
MINI-Bee
Sep 13, 2008 04:02 AM
1FSTMINI
May 11, 2008 07:30 AM
DaveTinNY
May 21, 2005 05:14 PM
