R58 Summer RF Tire
Old Sep 22, 2018 | 03:40 PM
Wayne Sakamoto's Avatar
Wayne Sakamoto
Summer RF Tire
I'm in the process of changing over to summer tires; my current setup is: 205/45/RF17 (all weather). I want to increase the width but maintain or stay close to the existing diameter. Appreciate anyone providing: Tire MFG and size information.
mahalo,
wayne
Old Sep 29, 2018 | 05:36 AM
a143gsxr's Avatar
a143gsxr
mahalo,
wayne
Take a look at tirerack.com. When I change tire sizes I look at the revs per mile column on the tire specs. you can find the revs per mile for your current tire and scroll down and see them all for a particular tire. Right off hand if you want to go wider and keep the same height you are probably looking at a 225/40 but that size is not readily available. 235/40 is available but only a few options in a pricey tire and it's meant for a 8" wide wheel but some are running it on the stock wheel. The best tire upgrade on the stock wheel for us is the 225/45/17. It is a hair taller by 0.7" but it only raises the car by 0.35" which is barely noticeable. And its .8" wider, that's what we are looking for.
Stephen
Old Oct 9, 2018 | 09:58 AM
Wayne Sakamoto
Thank you Stephen for the info appreciate it. I’ll research for RF Mfgs offering the size mentioned.
wayne
Old Oct 24, 2018 | 01:14 PM
Wayne Sakamoto
Update: I couldn't pull the trigger to +up on tire size; subsequently I missed out on Michelin's PSS4S tire. Instead I installed Michelin's Pilot Super Sports 205/45ZR17/XL (88Y). Wow what a difference from the run-flats: (1) Improved handling tremendously; on the way home I took a few S curves (normal drive home for me) steering very responsive/positive feedback to the steering wheel it feels lighter and direct. Powering through a 90 degree turn it's point and turn very grippy. When pulling on the straights you fell the tires digging in. (2) Ride improved smoother/softer and firmer not that jittery feeling on the run-flats. (3) Tire noise has gone down noticebly too. All in all I "love these tires". I rolled out of the shop just north of $800. Tires weighed in at 19.5lbs each, the run flats weighed in at 23lbs so I was able to drop 3.5lbs per tire. I had a chance to weigh my OEM Conical Spoke Alloy Wheel 7Jx17 - 23lbs. Last bit of info; I'm running 38 psig.
williamspaulr35
May 16, 2016 07:19 PM
cube17576
Tires, Wheels, & Brakes
Jan 26, 2007 05:36 AM
verbalassault
Jan 5, 2004 11:16 AM
