Ratting sound possibly coming from supercharger
Old Sep 21, 2018 | 06:24 PM
DScooperS's Avatar
DScooperS
My 2004 R53 is making a rattling sound that I think may be coming from the supercharger. It isn't overly loud, and seems to get better after the car heats up. Here is the process that lead me to question the supercharger.
The car has 87k miles on it, so I suspected a possible source of the rattle could be worn timing chain guides. After some research I found that the timing chain guide tensioner was a possible point of failure. So I replaced the tensioner, but no change was noticed to the rattle. I then noticed the belt tensioner has a slight vibration to it when the engine is running. Next step was to take the drive belt off and see if the rattle continued. Without the belt installed the engine runs perfectly smooth and quiet. So that tells me the noise is not timing chain or valve train related. All idler pulleys spin free with no play in the bearings. With the belt tensioner pinned in the retracted position, I could not feel any play in the tensioner assembly. Tensioner damper strut bushings looked ok. Crankshaft balancer had a TINY amount of play that you could barely feel and not visibly see. Supercharger rolled with a little effort, but rolled perfectly smooth. When reversing the direction of the pulley I could hear/feel a distinctive "clink" sound. If you rotated the pulley from one direction to the other quickly it made a "clink-clink" sound every time you changed directions. This is my first experience with a supercharger and I don't have any gauge at to what "normal" is. Is this a sign that it's time for a supercharger rebuild? Is it a sign of low oil level in the supercharger? Or maybe it's the belt damper/tensioner or crank damper pulley? Someone with more supercharger knowledge than me please let me know what's up!
Sorry this got so long, but hopefully if you made it this far you know what my problem may be. Thanks!
Old Sep 21, 2018 | 07:18 PM
Fastlane's Avatar
Fastlane
How many miles does this car have? Has the harmonic balancer (ie crank pulley) ever been replaced? If the 04 has the same as the later r53 cars (I think it may), you are probably on borrowed time if you have an original one. They basically come apart from heat and wear. The rubber that holds the inner and outer halves together degrades and it slowly (or suddenly) fails. I’d suspect that before the supercharger. Good replacements are the ATI or the PRW “fluid filled” type....don’t replace with OEM as it will just fail again.
You might also also use an auto stethoscope to pinpoint the source of the sound to make sure.
good luck!
0537Dave
GP Talk (2006)
Nov 8, 2014 06:05 PM
R99
Jun 22, 2014 08:47 PM
luthientier
Mar 30, 2014 08:15 AM
marimini
Apr 4, 2006 02:18 PM
Mini03Tiger84
23
May 10, 2005 07:59 AM
