R60 2012 SAll4 rear tires a mess and handling soft and sloppy
Old Sep 11, 2018 | 01:47 PM
Jwanck11's Avatar
Jwanck11
So, I am trying to figure out what the culprit likely is. This is a 70K mi car.
The insides of the rear tires are a mess - not smooth wear and worn out. The rear suspension also seems to be soft and sloppy. Going around a turn and hitting a bump results in the feeling of sideways sway and definitely soft (roll more than normal) almost as if the body is twisting.
I am looking at control arms, springs and shocks. Any thoughts if I'm on the right track or am missing something?
Old Sep 12, 2018 | 04:16 PM
Jwanck11's Avatar
Jwanck11
Nothing? No one has had the inner part of the tire wear unevenly and have the rear end get sloppy?
I was hoping for a bit of direction from someone who has been down this road before spending $100 for getting it on a lift to diagnose.
Old Sep 12, 2018 | 04:36 PM
cristo's Avatar
cristo
Alliance Member
The inside tread wears faster on the rears due to
negative camber, which is worse if the car has been
lowered, and wears faster if the toe is excessive.
if there is a lot of irregular wear, like cupping, I suspect
worn shocks which lets the tires bounce a bit after
hitting bumps or over rough roads. Feathering of the
tread often means excessive toe.
Old Sep 15, 2018 | 05:37 PM
Jwanck11's Avatar
Jwanck11
Great, thank you! Yes, it was cupped pretty badly. I installed loaded struts - because the price made sense.
Old Nov 1, 2018 | 08:16 PM
Alpha Motoring's Avatar
Alpha Motoring
Get an alignment, the toe is probably way off. The R60 naturally has a lot of negative camber, which is something to keep in mind.
marlinsfan
Jul 19, 2014 05:15 AM
Gabe3
Jul 31, 2013 03:49 AM
farfel
Dec 3, 2012 01:21 PM
siebharinn
Oct 19, 2012 06:17 PM
Z06C5R
Feb 12, 2009 05:00 PM
