R60 2011 Mini Countryman key fob, battery replacement
Old Sep 10, 2018 | 08:36 PM
kcasey59's Avatar
kcasey59
I have a 2011 Countryman. One of my Key fobs isn't working. Of course, I'd like to change the battery. This is a second generation fob, it is sealed, There is no place to lift or pry off the back, as a few videos on youtube show. How do I get it open?
Old Sep 13, 2018 | 02:04 PM
MrGrumpy's Avatar
MrGrumpy
You don’t, lol. I just had to replace mine because it stopped starting the car, but everything else with it worked still. You can take them apart and replace the battery yourself (according to MINI you cannot replace the battery unless you have comfort access) there are some videos on YouTube.
Basically you have to remove the metal ring, and then in the seam, use a box cutter or similar type of knife to slice it open all the way around, then you can pry it open. I did this, but was unable to fix it because my battery was still working fine. A few of the videos tell you the part # and where to get a replacement battery.
hope this helps!
kimkay
Aug 26, 2025 07:44 AM
RandyR90S
How to
112
Aug 8, 2024 12:24 PM
Armytrix_Exhaust
Jul 11, 2019 02:58 PM
rohicks
Jan 13, 2018 03:30 PM
-=gRaY rAvEn=-
How to
44
Jul 17, 2014 02:35 PM
