205/55/16 rub?
Old Sep 5, 2018 | 02:53 PM
Loccusst's Avatar
Loccusst
205/55/16 rub?
Does anyone have experience with running a 205/55/16 on the F57? I wanted to make sure they wont rub when the suspension compresses in turns. I have a set of winter tires on some 5x112 steel rims that I used to run on my 2006 VW GTI and I would like to not have to go buy an all new setup for my new car just for winter.
Old Sep 8, 2018 | 07:27 AM
NBCGLX's Avatar
NBCGLX
What's the offset of the wheels? 205mm wide tires won't rub by themselves (some factory MINI tires are 205mm wide), but the wheel offset can definitely affect that.
Old Sep 11, 2018 | 04:15 PM
harley0711's Avatar
harley0711
I am looking at the Michelin Defender T+H in 205/55R16 also and want to follow your post. I am about to order a 2019 Mini (NON S) signature - has 16” wheels,,,,, not convinced I will like the run flats???
Old Sep 12, 2018 | 04:10 AM
NBCGLX's Avatar
NBCGLX
I have a 2019 Justa with the 16” wheels (they’ll become winter wheels) and I’m just as unhappy with the runflats on this car as I was on my BMW. If I weren’t ditching the runflats in favor of snow tires in the next couple months, I would’ve ditched them as soon as I got the car. Whether 205/55-16 tires will fit on the factory 16” wheels without issue, I don’t know. I suspect the offset will be fine, but not sure. I also don’t know offhand what the width of the factory 16” wheels is, though I’m guessing it would probably be fine with a 205-width tire.
Old Sep 12, 2018 | 07:02 AM
Loccusst's Avatar
Loccusst
Tire Rack lists a 205 for the 16" wheel but recommends a 205/50 not a 205/55. I will still try it a test fit on the mini when I get some time freed up before winter. I hate the run flats myself and will go with a different setup in the spring for sure.
Old Sep 12, 2018 | 07:21 AM
NBCGLX's Avatar
NBCGLX
That makes sense because a 205/55 tire is overall taller than any factory tire option. That will cause the speedometer and odometer to read slower than reality. The speedometer is a bit optimistic from the factory, so likely no harm there. The odometer would likely be affected, however. Up to you whether that matters or not. Also, when you increase the overall size (diameter and/or width) of the tire, you could potentially run into other issues (e.g., tire rubbing suspension components, particularly when the suspension is under compression and/or the wheels are turned). Those are just some examples. Sometimes you can compensate for those types of issues by using a wheel with a different offset. Anyway, a 205/55 tire vs. a 205/50 tire isn’t much of a change, with the former being 0.8” larger in overall diameter than the latter. If someone else hasn’t already tried this setup and reported the outcome, you may have to just give it a go!
Old Sep 12, 2018 | 10:44 AM
Loccusst's Avatar
Loccusst
When I do I will definitely let everyone know.
Old Sep 12, 2018 | 08:15 PM
Clutch Wotan's Avatar
Clutch Wotan
I have testet 215/55/16 with on MINI Victory wheels, its ok.
https://www.facebook.com/f56.shiva/photos/a.1569909749893124/1589408387943260/?type=3&theater
Old Jun 10, 2025 | 05:24 PM
saw1's Avatar
saw1
205/55=16 on stock wheels
My 2018 has this size tire on the stock wheels, they were on the (pre-owned) car when I bought it last year. No rubbing noted, I am possibly considering a 12mm spacer to widen the track a little as I don't want to buy new wheels and tires at this time. The tires are Pirelli and NOT run flats.
Rob C
Tires, Wheels, & Brakes
Mar 13, 2007 02:16 PM
gtbuzzmini
Feb 5, 2007 11:19 AM
minifox2
Mar 16, 2006 04:24 PM
RUKnight
Apr 4, 2005 08:38 PM
Panganiban
19
Jul 8, 2004 10:14 PM
