motor is toast
Old Aug 21, 2018 | 01:48 PM
clubman2009's Avatar
clubman2009
motor is toast
Hi all. Well, my wife's '09 clubman bit the dust. It only has 98,000 miles on it and the timing chain let go. We now have a 2009 model paper weight.
Can I get a motor for this thing without having it cost me more than the car is worth?
Thanks,
Walter
2009 Clubman
Old Aug 21, 2018 | 02:40 PM
downshift1's Avatar
downshift1
car-part.com is your friend
Old Aug 21, 2018 | 06:13 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Sorry to hear that
Old Aug 22, 2018 | 07:28 AM
clubman2009
downshift-1
Thanks for the suggestion. I found a place that is only around 10 miles from my house and they have several motors. I'm sure I'll be using it for other cars too!
Walter
Old Aug 27, 2018 | 02:45 PM
clubman2009
I found a motor for my wife's '09 clubman. What is involved in swapping out these motors? I've done engine swaps on other cars, but they were rear wheel drive and they were 40+ years old -- Volvo, Triumph, Ford, Studebaker....
I don't know if I should get the motor and install it myself. If I have it installed, the cost of motor + installation will be what the car is worth or more. Any advice or suggestions?
Thanks,
Walter
'09 Clubman
Old Aug 27, 2018 | 03:11 PM
jglover's Avatar
jglover
$100 bucks for a Bentley Manual would be a wise investment at this point.
Old Sep 1, 2018 | 03:48 AM
MiniToBe's Avatar
MiniToBe
If the car is automatice, you can pull the engine and tranz from the top even though it is a little tight. But if it is manual, you need to get the nose out.
the removal is easy and everything is accessible. As mentioned above, you can get the manual or fine the same info here https://www.newtis.info/tisv2/a/en
There are few threads about engine swaps also that you could search for.
Old Sep 20, 2018 | 02:40 PM
clubman2009
Thanks for all the replies and suggestions.
We ended up selling the car and it was hauled away yesterday.
Hopefully I'll still be lurking around the forum with a new (to me) Mini in the future. I'll be on the lookout for a regular Mini with manual trans.
COOP3R
Jun 17, 2005 08:37 PM
Chitown_COOP
Tires, Wheels, & Brakes
Sep 28, 2003 10:41 PM
Calvin77
30
May 9, 2003 02:21 PM
orbhot
Feb 3, 2003 10:31 AM
