car turns over but won't start
Old Aug 6, 2018 | 08:29 AM
clubman2009's Avatar
clubman2009
Hi all. My wife's 2009 clubman is giving me problems. My son was driving the car and as he was pulling out of a parking lot, the car just stalled. We were able to get it started -- it bucked a bit but we were able to get it back into a parking stall to wait for the tow home. I got codes for several cylinder misfires. I changed all 4 coil packs and spark plugs. Car would turn over but not start. I changed the Crank Timing Sensor -- still no start. I replaced the relays -- still no start. I couldn't find any blown fuses, but maybe I missed some. What do I do next? Thanks.
Walter
2009 Clubman
Old Aug 7, 2018 | 12:14 PM
csq33r's Avatar
csq33r
Similar thing happened to my 2009 Cooper S last winter when it was really cold. It cranked but wouldn't start for two days. It was flooded due to carbon buildup on the valves. Not enough air coming in while cranking causes it to flood the cylinders with fuel. I got it to start using quick start, then did a carbon cleaning and it's been fine ever since.
Old Aug 7, 2018 | 01:53 PM
jglover's Avatar
jglover
Timing Jumped? (Sorry for Saying That)
Old Aug 7, 2018 | 02:07 PM
clubman2009
How would I know if the timing jumped?
Old Aug 7, 2018 | 02:08 PM
clubman2009
I also forgot to mention that I am getting an Amber Key sign when I put the "key" in the slot.
Old Aug 8, 2018 | 09:06 AM
jglover's Avatar
jglover
It a take the valve cover off and see if your marks line up.
Also youtube mini cooper timing chain replacement and it will show you how to line up marks.
Old Aug 8, 2018 | 09:41 AM
clubman2009
I will check the timing when I get a chance to pull off the valve cover. I tried to start the car with ether yesterday, but it just cranked over and did not start.
Somebody mentioned that perhaps the key lost its memory and is not being read by the computer. Is that possible that it would happen to both keys? If so, can I reprogram the keys?
Thanks,
Walter
Brianaes
Mar 8, 2018 07:56 PM
NeonLed
Nov 27, 2017 10:58 PM
ChuckBZ
Jan 13, 2017 11:33 AM
SFarbolin
Dec 7, 2014 09:52 PM
BLavin
Dec 9, 2011 08:47 PM
