R52 Beltline trim repair with inner tube
Old Jul 26, 2018 | 02:55 PM
Tgriffithjr's Avatar
Tgriffithjr
Hi all!
Well I decided to forgo replacing the Beltline trim on my 06s for now. Always one to find a way to make something in an unconventional manner I decided to try a bicycle inner tube to replace the broken and cracked seal that everyone with a convertible eventually must contend with. Here are a couple of photos of the finished product. I’m not completely happy with the outcome as this was a trial attempt to determine if it was even possible.
I am going to regroup and find a better way of making it work. I will then do a complete step-by-step write up with photos. I believe it’s possible to make this look very professional, but it will take a little thought. I did this in only two hours. I intended this as an experiment. I will now try and perfect.
Attached Thumbnails Beltline trim repair with inner tube-2da39f4b-6395-42f7-a42d-f56cea84e39d.jpeg   Beltline trim repair with inner tube-e44e39e3-37d3-470f-a4e2-057e53a1995c.jpg   Beltline trim repair with inner tube-4ac6c1d8-6a49-43d5-93fc-feb49a6205e9.jpg
Old Jul 26, 2018 | 03:01 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Not bad, I went another route.
More info below. I did use rubber strips that I glued with exterior black car contact cement under the light.
https://www.northamericanmotoring.co...ng-away-3.html
Old Jul 26, 2018 | 03:26 PM
Tgriffithjr
Yes I saw that and I remember you saying that an inner tube might work. I believe that with enough thought the tube could work well. Just have to hone out all the bugs. I’ve already thought of a couple of new things to try.
isthar
Apr 11, 2011 01:25 PM
isthar
R55 :: Clubman Talk (2008+)
Apr 11, 2011 12:03 PM
kevinyu21
Jan 5, 2009 08:49 AM
toolazyforalogin
Jun 30, 2008 07:24 PM
