R56 How to clean up filthy heater controls
Old Jul 20, 2018 | 11:59 AM
MDifficult's Avatar
MDifficult
Hi,
I’m in the process of buying a 2009 R56 Mini One for my daughter. The car is in great condition but like all Minis of this age with the basic air conditioning, the heater speed and temp controls are grey plastic and look worn and filthy.
It’s clearly a common issue as every car I looked at and every second hand heater control panel on eBay has the same issue.
So, any tips on either how to clean them, or has anyone got a good guide on how to refurbish them? I’m reasonably handy so if it’s a case of removing, sanding, painting and fitting I could do it, but would like the confidence boost of someone doing it successfully first!
(Edited to add the following picture)
Cheers
Old Jul 20, 2018 | 12:37 PM
SeattleCooperS's Avatar
SeattleCooperS
Remove the buttons simple green them and soak them and you could swap some of the black buttons from the LCI or paint them.
Old Jul 20, 2018 | 12:44 PM
ammodave's Avatar
ammodave
I cleaned mine in place with ordinary rubbing alcohol, did a good job.
Old Jul 20, 2018 | 12:48 PM
MDifficult's Avatar
MDifficult
Great, are the black ones a direct swap? And what’s ‘simple green’? (I’m UK based and haven’t heard of that if it’s a product)
MDifficult's Avatar
MDifficult
Ah, that sounds good! That’ll be what I try first. Cheers
Old Aug 11, 2018 | 04:13 PM
gizmo83's Avatar
gizmo83
Be careful with the rubbing alcohol. I cleaned it in place as well and I went over it too many times that the soft-touch/rubber coating came off with it. It's shiny plastic now but at least it's clean? (Side ***** are gray plastic, center **** is black plastic)
I do want to take it apart and paint it but it's so much work to get it out of the dash.
cartpix
Electrical
Oct 31, 2011 08:45 AM
cartpix
Electrical
Oct 27, 2011 09:43 AM
StillK
Dec 11, 2008 09:25 AM
D.J.
Off-Topic :: Autos
Jan 28, 2004 09:16 AM
