R56 R56 Tachometer connector pinout? (need CAN high/low)
Old Jun 28, 2018 | 08:05 AM
Carrboroman's Avatar
Carrboroman
Hello,
I'm in the process of adding an AIM MXL2 dashboard on my 2013 MCS.
It connects through CAN high/low, and needs ground and 9-15V feed.
While the AIM manual suggests to hook at the gateway connector, I was wondering if the OEM tachometer cluster connector has CAN bus high/low, ground and power (when key inserted)
Does anyone has a pinout/schema for such connector?
Thanks a lot!
Old Jun 29, 2018 | 06:58 AM
MiniToBe's Avatar
MiniToBe
you can actually spice at the OBD socket...The CAN bus wires are the yellow/black (D_CAN_H) and yellow/brown (D_CAN_L). also see this
https://www.newtis.info/tisv2/a/en/r...19527/CkNrhPmM
Old Jul 5, 2018 | 06:31 AM
Carrboroman
Thanks, but I needed to connect the harness at the tach plug :(
Anyway, the shop already made the wiring, will post the pinout when I get the car back!
Cheers!
Edit:
OK, turns out the Kombi connector has CAN bus but the wrong one (so I've been told by the shop), they proceeded hooking the dashboard at the gateway connector. Also, I asked for key-on power, but so fare they could only connect to the fuse box with engine-running...I'll try to get this on-key instead.
Thanks for the help!
njaremka
Electrical
Mar 6, 2017 11:07 AM
TampaMCS
Jan 12, 2017 08:14 PM
godzilla
Oct 13, 2009 06:44 AM
PGT
Aug 19, 2007 07:45 PM
