Drivetrain Recent Mods
Old Jun 19, 2018 | 08:23 AM
kscw's Avatar
kscw
Recent Mods
Hi all! Been an R60 owner (2012 CMS All4) and forum reader since 2015, but I just officially registered and this is my first post. Recently purchased some upgrades and finally installed them: NM Module, Sprint Booster, aFe drop-in replacement air filter. Module is set to high and I exclusively run 93 octane (I've never run less than 91 since owning the car at 11K miles). Definitely noticeable power increases...but I get a hesitation or "bucking" during acceleration since putting in the NM. I've been running the replacement filter prior to the other mods and never had an issue. Would upgrading to a higher flow 360 degree filter help with this?
Old Aug 6, 2018 | 04:50 PM
MrGrumpy's Avatar
MrGrumpy
Awesome, first post and everyone left you hanging. Welcome! Now to the issue....did you ever solve it? I have seen some other threads with the same type of issue with the NM Module. If I recall correctly, it has something to do with the high setting. Try adjusting it to the lower setting and see if that cures it. Good luck
Old Aug 8, 2018 | 09:37 AM
AWD_Rally's Avatar
AWD_Rally
Moderator
Veteran: Marine Corp
Have you tried taking out the NM Module and going for a test drive?
A different intake/360 filter wont help much, if at all. The stock box actually flows quite a bit of air, more than what most people will need. Plus it keeps it as true to a cold air intake as possible.
Old Aug 8, 2018 | 10:30 AM
MrGrumpy's Avatar
MrGrumpy
^+1
This is absolutely true! I had a cone filter on my intake and made my intake air temps at least ten degrees hotter than with the factory airbox. I switched back. It’s quieter, and I do love the turbo sounds, but between the intake temp and the fact that the DV+ is super quiet too, there was just no logical reasons to keep it that way. Save the $ from an intake and put it towards an ECU tune or something else that will provide an actual real improvement.
kscw
11
Jun 20, 2018 08:23 AM
cguzz
Mar 16, 2015 08:56 PM
SAR4H
Mar 16, 2008 01:41 PM
