R56 JCW Exhaust Tip Set Screws. Available?
Old May 10, 2018 | 02:39 PM
gkp's Avatar
gkp
Does anyone know if MINI sells just the set screws for the JCW tips? I looked at the parts sites and don't see them listed separately. Or have any of you come up with an alternate way of affixing the tips to the pipe? I destroyed mine while getting the tips off the old exhaust.
Old May 11, 2018 | 08:44 AM
jcwcoopster's Avatar
jcwcoopster
Wow at least you got the screw out. I would just go to a hardware store and match it up with a stainless steel bolt and washer. Easy Peasy.
Old May 12, 2018 | 07:11 AM
gkp's Avatar
gkp
Something along those lines is Plan B. The MINI nut is built in such a way that it inserts securely into the tip.
Old May 12, 2018 | 08:59 AM
RB-MINI's Avatar
RB-MINI
A half hex body rivnut might work.
Old May 12, 2018 | 09:24 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
https://www.mcmaster.com/#set-screws/=1ct783p
Old May 12, 2018 | 09:37 AM
RB-MINI's Avatar
RB-MINI
gkp, from your pics it looks like the threaded insert is missing because of the hexagonal hole and it looks like the insert is rusted to the set screw. Looking at pics of new JCW tips, the hole is round and the threaded insert looks to to be completely recessed.
Do you have any more pics of the tip and are there still threads in it?
Old May 14, 2018 | 08:28 AM
Yep it has a set screw and a bonded type nut insert. I dont have one in stock to check but that what it looks like stock. The screw is not available on its own.
Old May 14, 2018 | 04:24 PM
jcwcoopster
Yes but a proper fitting set of hex head screws (stainless) and stainless washer should be all that the OP needs to rea-fix the tips.
Old May 15, 2018 | 05:50 AM
gkp's Avatar
gkp
The tip itself is not threaded. The threaded insert snapped into the hexagonal hole and the set screw (really a bolt) screwed into that. Leave it to MINI to reinvent the wheel.
Old May 15, 2018 | 12:26 PM
jcwcoopster
looking at the first picture you posted it looks as if you could get stainless steel nut to fit the cavity completely, bond it in place, then put a stainless steel bolt/screw through the threaded portion and should perform/act like the original.
Old May 16, 2018 | 05:50 AM
gkp's Avatar
gkp
Something along those lines is Plan B. I was hoping the original hardware was available as a cleaner solution.
Old May 16, 2018 | 10:01 AM
jcwcoopster
Unfortunately Mini will have you buy new tips to get the new hardware. By you installing stainless steel inserts and bolt it will last longer than the last implementation.
Old May 10, 2020 | 11:27 AM
Tracy-Louise Peyton's Avatar
Tracy-Louise Peyton
Question...
Quick query..anyone know what "m" these screw are? E.g. m6, m10 etc...cheers all xx
Old Jun 18, 2020 | 04:10 PM
Arishtat's Avatar
Arishtat
My set screw is pretty corroded, but it looks to be an M6x1.0 and it is 20mm long. The hex opening is exactly 3/8" wide which translates to 9.525mm so I'm going to repair mine with an M6 half hex rivet nut, a 25mm stainless flanged button head screw which will be filed down a bit, and some lock tite.
Amazon parts:
M6 flanged button head assortment: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
M6 half hex rivet nuts: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old Jun 21, 2020 | 12:24 PM
Arishtat's Avatar
Arishtat
Amazon parts:
Update: Success! The M6 half hex rivet nut is a perfect fit. For the screw use an M6x25mm. It will be a little long so you can either grind it down to ~22-23mm or space it out with a flat washer and lock washer combo.
if anyone can find an M6x20mm set screw that would work even better.
Old Jun 27, 2020 | 06:13 AM
gkp's Avatar
gkp
What did you use to bond the rivnut to the tip?
Kitchenboy
May 20, 2020 02:35 PM
SalemMINIDriver
Jun 14, 2017 01:36 PM
Nimcosi
May 30, 2009 07:38 PM
ngweibing
Aug 26, 2008 10:32 AM
