R56 New Spyder headlights for my R56
Old Apr 20, 2018 | 11:45 AM
miniuy's Avatar
miniuy
I'm in the way of installing a new set of F56 (Spyder) headlights with LED H9 bulbs (not included) to match the LED halo color temperature.
Actually I'm running the (awesome) Spec-D Black Halo Projector headlights with Kensun HID kit with no problems at all from more than 4 years ago.
Because my MINI is halogen from factory, I have added the proper VO code to get the HID headlights working.
My question:
Should I delete the HID VO code in order to install the LED kit or I should/can install it with the HID VO code active?
Old May 8, 2018 | 07:42 AM
miniuy's Avatar
miniuy
any advice guys?
Old May 8, 2018 | 08:14 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If the HID code is there to remove the bulb check for HID lights, I would leave it alone. Should be pretty easy to visually see if one of your LED bulbs goes out.
Old May 9, 2018 | 08:11 AM
miniuy's Avatar
miniuy
No, it's not related with enable/disable cold & warm checks.
It's related with the Vehicle Order.
It's halogen from factory and now it's running projectors with HID, then, I have added the VO to tell to the car that it's running HID instead of halogen (HID will shut off when engine is on if the HID VO code is not present in the config)
Old May 9, 2018 | 09:47 PM
bcriverjunky's Avatar
bcriverjunky
My car was factory halogen and I didn't do anything when I switched to HID in Helix projectors. I even put HID in the fogs. I used Morimoto bulbs, ballast, and Canbus harness. No issues. Nice to be able to see the road finally.
Old May 10, 2018 | 01:02 PM
miniuy's Avatar
miniuy
In my case I have moved to Depo Plug&Play projector headlights with Kensun HID kits.
It worked with the engine off but with the engine on.
Add the VO related to "equipped with HID" was the fix to get all working
pilotof626
Aug 28, 2018 07:05 AM
Feb 10, 2017 01:52 PM
Feb 10, 2017 01:49 PM
Feb 10, 2017 01:37 PM
MazMini
Jul 4, 2016 07:23 PM
