FS:: 2006 MINI Cooper S - Clean, low miles!
Year: 2006
Model: Hardtop
Price: $9750
Mileage: 57000
Color: Pepper White
It's a late 2006 production build with Premium package, LSD, Tartan Red cloth and Panther Black leather combination upholstery, and MINI seven piano black dash trim. It's a bit of a unicorn.
This is an incredibly clean MINI, almost impossibly clean for the year. No accidents. No rust. Garage kept. 3 owners. Dealer maintained at Princeton MINI, Helix Motorsports, and personally maintained by me with spreadsheets and records and receipts for everything I've done. You're buying a car that's been gone over with a fine tooth comb by myself and master MINI technicians and is ready for many more miles of carefree motoring. Recent NJ inspection is good thru October of 2019. I've driven it to Tennessee, North Carolina, and all over Pennsylvania and New Jersey. Vehicle has never been tracked or autocrossed.
No leaks, internally or externally. No dents. Paint is all original to my knowledge, and in fantastic shape. Some small chips and imperfections do exist but are few and far between, and have been touched up where possible. The only scratches are in 2 locations: (1) under the gas door and (2) on the rear hatch. I've waxed and sealed the paint with Prima Epic and Sonax Polymer Net Shield. Interior has been cleaned and protected with a combination of Einszett Lederpflege and Sonax Cockpit Premium. All rubber seals have been conditioned with Einszett Gummipflege. Sunroof has been disassembled, cleaned, lubricated, and re-assembled. Sunroof drains are firmly attached and secured with zip ties to prevent any sunroof drain leak issues.
Oil has been changed with Mobil 1 0W40 Euro blend every year. Brake fluid has been flushed annually. Recent drain and refill of transmission oil with Redline MTL. Fuel has always been 93 octane and top tier gas.
Alignment is custom, with 2 degrees of camber in the front, and 1.5 degrees in the rear. Toe is set to 0 degrees on all 4 corners. Handling is incredibly neutral.
Car will come with a set of OEM R108 multispoke wheels in black and with a set of 215/40R17 Yokohama Advan AD08R tires.
One caveat: The Raceseng Slammer shift **** pictured will be replaced with the OEM shift **** at time of sale.
Price: Firm, no trades (One exception: Miata may be considered)
Warranty: As-is.
Payment accepted: Cold hard cash only.
Last 7: TN26435
Maintenance:
New door and hatch seals
New water pump & water pump gasket
New belt tensioner
New idler pulley
New cooling fan
New coolant expansion tank
New passenger side motor mount
New intake air hose
New cabin air filter
New sunroof glass support brackets
New front bumper marker light assemblies
New 3rd brake light assembly
Suspension:
H&R Street Performance Coilovers
Ireland Engineering fixed front camber plates
Hotchkis H-sport Comp 22mm rear sway bar
Cabrio braces on front strut towers
Brakes:
R56 Cooper S front calipers, stock rear calipers
Pagid High Carbon rotors
Stoptech Street Performance pads
Stoptech Stainless lines on all 4 corners
Motul RBF600 brake fluid (bled annually)
Engine:
Cravenspeed 15% supercharger reduction pulley
Cravenspeed dipstick
DDMWorks Intake w/K&N filter
JCW exhaust, non-resonated
Superpro lower engine mount insert
PRW fluid-filled harmonic balancer
NGK 6988 iridium plugs
Other:
OEM Driving lights with covers
OEM Auxiliary input for external audio
Helix short shifter
OSRAM Rallye 65w bulbs installed for high beams and low beams
Redlinegoods genuine leather shift and handbrake boots with red contrasting stitching
Rear wiper motor was removed due to clogged washer nozzle and seized rear wiper. Harness is secured and intact under the rear hatch trim panel should you wish to reinstall a rear wiper assembly.
For more photos: https://zrepp.smugmug.com/Automotive...s/Project-R53/
Keywords: 2006 MINI Cooper S, 2005 MINI Cooper S, R53, MINI Cooper, MINI, manual transmission, hot hatch, pepper white
Pretty interested in the car, would like talk to you about it. Feel free to DM me
All messages responded to.
I'll have new photos up shortly, as well, and I have a full set of Schroth Quick Fit harnesses in red with pads ($350) and a set of 17x8 Team Dynamics Pro-Race 1.2 wheels for sale ($600).
In
Meet Project R53. My 2006 MINI Cooper S that I've painstakingly restored, cared for, and improved upon over the last 2.5 years. Why am I putting it up for sale? Well, I no longer work for a MINI dealership (Princeton MINI closed), and I now work for Mazda. As such, I've purchased a Miata to replace the MINI. Do I want to get rid of the R53? Absolutely not... but I probably should, as I don't have enough time to dedicate to having 2 fun cars in the garage.
Warranty: As-is.
Last 7: TN26435
Maintenance:
New belt tensioner
New idler pulley
New cooling fan
New intake air hose
Suspension:
Brakes:
Engine:
Other:
Helix short shifter
Warranty: As-is.
Last 7: TN26435
Maintenance:
New belt tensioner
New idler pulley
New cooling fan
New intake air hose
Suspension:
Brakes:
Engine:
Other:
Helix short shifter
Alpha Motoring
Feb 2, 2018 07:54 PM
MiniMeR50
May 26, 2015 04:36 PM
MiniMeR50
Jan 1, 2015 09:33 AM
erik99
Feb 21, 2013 07:37 AM
justinmonroy
MINIs and Minis for Sale (archive)
25
Jun 17, 2007 09:52 PM
