R55 In middle of engine swap
Old Mar 14, 2018 | 07:16 PM
ADOR's Avatar
ADOR
I am in the middle of swapping a 82K mile N12 into my 08 Clubman. Got the engine out and swapping out what I need on it. Did little things already like putting a new crank to AC belt already.
The trans fluid looks dark so I am going to read up on that tonight and find the right filter and trans fluid tomorrow and get that done before I put the trans on the new engine. (just going to change it, not flush the trans that can cause problems if it wasn't done regularly.
Anything else that you think needs to be address while I have it tore down?
Old Mar 14, 2018 | 09:17 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
As long as you have the transmission separate from the engine, replace the engine crankshaft seal. Easy to do now, a pain to do later.
Old Mar 15, 2018 | 04:52 AM
MiniToBe's Avatar
MiniToBe
oil filter housing gasket.
reseal areas of old leaks
zzMini
Jun 30, 2008 05:52 AM
SilverCooperS
Feb 27, 2004 03:21 PM
drstevenj
20
Aug 28, 2002 09:58 AM
