F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Adding alarm to 2017 Clubman
Old Mar 4, 2018 | 03:13 PM
Eric_Rowland's Avatar
Eric_Rowland
Wife is looking into a 2017 Clubman. The only thing it's missing is the alarm and she's jonesin' for it.
Is it a possible add? The MINI accessory catalog says the last year it's available is 2014.
Any info appreciated.
Old Mar 4, 2018 | 03:26 PM
anotherminiinthegarage's Avatar
Factory alarm is integrated into the MINI I believe
Aftermarket (non-MINI) is probably your answer
Old Mar 4, 2018 | 08:50 PM
Eric_Rowland
Meaning it's either from the factory or not an option for add-on? Bummer.
Added the OEM to my '04 and it was all plug-n-play.
Old Mar 5, 2018 | 09:14 AM
2017All4's Avatar
2017All4
Super Moderator
It is my understanding that it depends on what other features the car has.
I've got to believe dealers have a way to boot up the alarm (or some sort of aftermarket alarm that is compatible) as there must be many buyers who want the alarm feature added.
Start here: https://www.shopminiusa.com/PRODUCT/...-ALARM-SYSTEM#
Old Mar 5, 2018 | 10:39 AM
Eric_Rowland
Originally Posted by 2017All4
Yeah, that's where I started that said the retrofit only applies up to 2014.
Will have to check with a dealer. Thx.
Old Mar 5, 2018 | 04:15 PM
2017All4's Avatar
2017All4
Super Moderator
Sorry that the shopminiusa was a blind alley. I thought for sure they would have updated their offerings to include something for the F series Clubman.
Please let us know what the dealer says. The Alarm was a $500 option with a factory order, so that should give you a price range.
Old Nov 18, 2018 | 03:33 PM
Eric_Rowland
She pulled the trigger!
Now, can we add an alarm?
RealOEM says PN 65759383320
http://www.realoem.com/bmw/enUS/show...diagId=65_2599
ECS Tuning - is that NLA as I see on your site?
Old Nov 19, 2018 | 07:15 AM
Just saw this, Checking with MINI as its very new.
Old Nov 19, 2018 | 05:27 PM
NBCGLX's Avatar
NBCGLX
I'll let ECS Tuning confirm, but I do believe you can retrofit it. I'm guessing the hardware (i.e., the siren, and locking/unlocking sounds) will work out-of-the-box. However, I believe you have to code the VO to add the alarm option code to get the alarm to fully function. Did this on my BMW, but this was back in 2011 or so.
Old Nov 20, 2018 | 06:57 AM
The new part is 5759493759 and yes we can get them.
https://www.ecstuning.com/b-genuine-...759493759~oem/
Old Nov 20, 2018 | 11:33 PM
Eric_Rowland
Funny that my google to this answer came up with my post here from 8 months ago.
Apparently since then they've made the alarm unit available post factory. Yeah! Happy wife, happy life.
Now to figure the best way to get it coded. Thanks for the correction, ESC - glad it's not NLA!
Old Nov 21, 2018 | 07:33 AM
Welcome.
Old Nov 22, 2018 | 07:16 PM
ranger052's Avatar
ranger052
Hi
227 thats the cost of the whole alarm system ? factory mini alarm?
Thank you!
Old Nov 25, 2018 | 09:18 PM
zagman's Avatar
zagman
Anyone figure out the coding?
Old Nov 26, 2018 | 10:05 AM
Originally Posted by ranger052
Hi
Thank you!
https://www.realoem.com/bmw/enUS/sho...99#65759493759
Thats just the tilt alarm horn
Old Nov 26, 2018 | 09:19 PM
Eric_Rowland
Is any other part(s) needed? Do you need to get the bracket separately?
Old Nov 27, 2018 | 06:17 AM
Yeo, its holds the tilts sensor, I have not seen a MINI with that already installed, same with the install hardware, just make sure its prewired up there, you should have a little plug hanging out or it might be wrapped in the main harness up there just like the older MINI models.
Old Nov 27, 2018 | 09:03 AM
Eric_Rowland
My R53 had the complete retrofit instructions.
Do you know if there are pictures of the connector location somewhere? Per realoem it looks like the alarm lives in the boot instead of under the bonnet like the R53. TIA
Old Nov 27, 2018 | 12:59 PM
Yes, hold on. Found it.
https://www.newtis.info/tisv2/a/en/f...tem/1VnYjwwcTN
https://www.newtis.info/tisv2/a/en/f...tem/1VnYScSnt4
https://www.newtis.info/tisv2/a/en/f...tem/1VnYM98Els
Old Nov 27, 2018 | 06:51 PM
Agbullet25's Avatar
Agbullet25
So based on what newtis shows, the ultrasonic interior sensor is already integrated into the overhead control module and monitors the latches and hood for possible breaking and entering into the car. Therefore all that'd be needed is the tilt sensor/alarm and install it in the rear trunk area, then program?
Old Nov 27, 2018 | 09:01 PM
ranger052's Avatar
ranger052
Wait, so my mini is already pre wired and I just need that trunk thing to fully have the alarm?
Old Nov 27, 2018 | 09:09 PM
Agbullet25's Avatar
Agbullet25
That's what I was thinking but was trying to get clarification on.
Old Nov 29, 2018 | 04:05 PM
Eric_Rowland
I may end up being the guinea pig on this one. TIS does seem to indicate that Agbullet25 is right.
Old Nov 30, 2018 | 05:13 AM
Let us know, Thats all the info I have, my guess is that its those parts and a flash. Based off the older MINIs and what MINI is doing on the wiring harness side on future generations I bet its parts and a flash update to the ECM.
Old Dec 1, 2018 | 09:30 PM
ranger052's Avatar
ranger052
Yes let us know Thanks!
