2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Lowering Springs
Old Feb 16, 2018 | 02:34 PM
cmartyna's Avatar
cmartyna
Question Lowering Springs
Anybody have lowering springs for the F60 yet? Really would like to lower it and get better handling. My F60 does have Dynamic Damper Control too so needs to be compatible...
RECOMMENDATIONS??
Old Feb 17, 2018 | 04:52 AM
MrFunk's Avatar
MrFunk
I'm not sure you're going to improve the handling a ton with a mild drop. I also think you may ruin the ride if you'd only doing springs which I'm sure you would in order to preserve the dynamic dampers. Your spring to damper rate will be WAY off with any kind of stiffer spring, especially if doing an aggressive lowering. I'd suggest instead look at a rear sway and perhaps solid end links if they make em for these... better tires can go a long way also (the oe's are garbage IMO). I actually think it rides pretty good in sport mode.
I'm all about lowering and improved handling but this just doesn't seem like the right vehicle for that if you ask me.
To answer your question - I haven't seen springs for it anywhere.
Old Feb 17, 2018 | 06:12 AM
cmartyna's Avatar
cmartyna
I am not too worried about a stiffer ride. My last MINI (Cooper 4 door hardtop) was lowered with NM lowering springs and it felt like a MINI should. It handled sooo much better too and looked so much better! MINIs should be that way from the get go since they are known for Go Cart Handling! So I am not too worried about "ruining the ride". LOL My goal is to make the car look better and get rid of some wheel gap, improve the handling slightly, and to have a stiffer ride. The F60 is a big vehicle so any drop I can imagine would improve it. I just have been unsuccessful trying to find any kind of aftermarket springs...
Old Aug 30, 2018 | 06:23 PM
Propak's Avatar
Propak
H&R has them for the f60 now. Supposed to give a 1.2” drop front & rear.
Old Sep 12, 2018 | 08:04 PM
bluonyx's Avatar
bluonyx
Come on, someone order them and give us a before and after write up!
Old Sep 13, 2018 | 01:00 AM
ND40oz's Avatar
ND40oz
KW has coilover kits that come with EDC deactivation modules, if you want to go that route. It's surprising they don't have a plug and play DDC kit yet, maybe with the new X2 M35i that'll encourage them to produce one.
http://www.kwsuspensions.com/product...-102200bp.html
http://www.kwsuspensions.com/kw-susp...-352200bp.html
Old Sep 14, 2018 | 08:04 PM
Propak's Avatar
Propak
My HR lowering springs came in on Thursday and i will be installing them on Saturday (9/15). I’ll post some before and after pics.
Old Sep 16, 2018 | 07:33 PM
Propak's Avatar
Propak
Did a quick video of my F60 after the H&R lowering spring install. Already a 1.5” drop and I think it still will settle a bit more. Looks great but now it may need some bigger wheels and/or some spacers to get it looking just right. Heres the link.
. Putting together an install video that will be up later this week.
Old Sep 16, 2018 | 08:42 PM
Evlkarl's Avatar
Evlkarl
Thanks for the Video the car looks good. Here are some pics of a F60 that B and B from Germany spruced up a little with 20" wheels. By any chances can you please post the product/model number of the H@ Springs. Thank you.
Old Sep 17, 2018 | 02:47 PM
Propak's Avatar
Propak
That's a good looking F60. I'd like to get the wheel and tire specs on it. I'll do some research. The model number for the H&R Lowering springs is 28790-1. I picked them up from Tirerack although ECS has the available as well. https://www.tirerack.com/suspension/...=Cooper+S+ALL4
Old Sep 17, 2018 | 03:47 PM
Evlkarl's Avatar
Evlkarl
Propak, Thank you for the quick reply.
Old Sep 17, 2018 | 05:44 PM
Propak's Avatar
Propak
Here's a 30 minute video of the install. I'm no videographer but you'll get the idea!
Old Sep 18, 2018 | 05:54 AM
Looks good. The F60 has so much lift to it when you do lower you still have some wheel gap. Lower profile/larger wheels and spacers will help that.
Old Sep 18, 2018 | 05:51 PM
Propak's Avatar
Propak
That's gonna take some math to figure out. All that offset & backspacing stuff is critical to figuring out all the spacer & tire/wheel size issues when going to 20" wheels.
Old Sep 18, 2018 | 08:45 PM
Evlkarl's Avatar
Evlkarl
Propak, here is the link to BB Tuning in Germany maybe you can send them an Email. If you have no luck PM me and I will try to get in touch with them since I am fluent in German.
http://www.bb-automobiltechnik.de/de...tartseite.html
here is the info for the email address
http://www.bb-automobiltechnik.de/de...men/index.html
Old Sep 20, 2018 | 06:28 PM
Propak's Avatar
Propak
Looks like 225/35-20’s on the 20 inch rims. The 19” JCW rims have a 47mm offset which I assume fit without a spacer. I would think a 20” rim would need a 52mm offset. Just guessing tho.
Old Nov 5, 2018 | 12:18 PM
LiL Stinker's Avatar
LiL Stinker
Will these work on a 2018 Counryman S 2 wheel drive?
Old Nov 6, 2018 | 10:58 AM
https://www.ecstuning.com/Mini-2018-...nsion/Springs/
Spring Options Above^^
Old Nov 30, 2018 | 07:41 AM
TheOriginalKonky's Avatar
TheOriginalKonky
Originally Posted by Propak
Did a quick video of my F60 after the H&R lowering spring install. Already a 1.5” drop and I think it still will settle a bit more. Looks great but now it may need some bigger wheels and/or some spacers to get it looking just right. Heres the link. https://youtu.be/iDeTSWB4Npk
Did they settle any more from the first pictures you posted? If so, do you happen to have a new picture you can post? TIA
Old Nov 29, 2019 | 08:28 AM
ny_yankee's Avatar
ny_yankee
Now all you have to do is push those baby's out a touch. Spacers.
I have been racking my brains on getting taller tires to fill out my new 19 CMS but you've inspired me to just lower it! I just ordered the H&R's, I did also purchase new wheels that I'll be swapping out the P7's with, with a et40. I was looking for another tire also (softer) but to be honest the P7's aren't that bad. I'll post up soon.
Old Dec 11, 2019 | 11:21 AM
ny_yankee's Avatar
ny_yankee
So how much of the ride was lost from stock springs to H&R's
Old Dec 11, 2019 | 12:34 PM
Just a head up we have one system on sale for coilovers on the F60/F54
https://www.ecstuning.com/b-kw-suspe...rs/180200bnkt/ limited quantities 30% off. and for DDC you will need these. https://www.ecstuning.com/b-kw-suspe...e/68510477~kw/ Some people have told us that they just disconnected the DDC system and never got an error.
Just an option if you want more then springs
Old Jan 4, 2020 | 11:26 AM
WeBad_Paceman's Avatar
WeBad_Paceman
Were you able to retain factory alignment specs without any camber plates or anything with these lowering springs?
Old Feb 3, 2021 | 10:28 AM
Jason Martin's Avatar
Jason Martin
I called H&R and they said the ones they make are only for the F60 All4. there is too much conflicting information online, I called Mini Mania and they say they have them I just do not spend the Money and they won't work.
Can anyone clarify this for me?
Thanks in advance!
Jason
Old Jan 24, 2024 | 04:52 AM
KalenaR's Avatar
KalenaR
Nice looking Countryman. We just bought a 2019 Countryman S. We are planning on lowering it as well. Thank you for posting the videos. I noticed your caliper covers. Could you tell me where you bought them? I went up to the MGP site and the MINI only goes to 2015 when I do a vehicle search. Thank you for your help. Have a blessed day!
