2011 MCS All4 2C57, 2C90, 2C91
Old Feb 2, 2018 | 05:06 AM
ig109's Avatar
ig109
2011 MCS All4 2C90, 2C91
Mini Countryman.. Still somewhat new to me, had it about 4 months.
It has had a plethora of codes over the time I've had it. the only ones remaining are these. 2C90, 2C91.
When I began looking into these I contacted original owner who told me that the turbo, HPFP, and Vacuum pumps had all been replaced at the end of his extended warranty period.. The bypass valve is a new Forge unit and seems to function properly.
Haven't checked for boost leaks yet..
Haven't had chance to check the wastegate functionality.
The boost pressure thru the OBD port read on the bluelink app is ~9psi.
Anyone encounter something similar?
Old Mar 26, 2018 | 12:57 PM
ig109's Avatar
ig109
for anyone following this the issue ended up being a sticking FORGE bypass valve.. I replaced it with a stock valve and the issue has yet to reoccur.
Old Aug 8, 2018 | 10:21 PM
MrGrumpy's Avatar
MrGrumpy
Good deal, I’m glad it worked out.... sorry you didn’t get any help from the community
Old Mar 10, 2021 | 05:37 AM
Vanski's Avatar
Vanski
Forge bypass Valve?
Forge bypass Valve? What is that and where is it located? On the turbo?
minicountrymanS
Feb 2, 2019 12:48 PM
WayMotorWorks
49
Jan 30, 2015 09:51 AM
Thruxton
Nov 30, 2011 02:55 PM
countryboyshane
Apr 26, 2009 05:10 PM
