R50/53 Engine differences between early/facelift
Old Feb 1, 2018 | 10:40 AM
CSP's Avatar
CSP
Hey y'all,
So... long story short - I need to either rebuild or replace my engine. I know there were updates to the engine as the r53 progressed, but I'm not sure of the extent of them. Is it limited to accessories? Pretty sure the oil filter housing was updated, the PCV, and a few other things - but what about the block/head itself? If I buy a long block from an 02-03 will I be taking a step back? or can I just swap my accessories and be good to go?
Old Feb 1, 2018 | 10:46 AM
Whine not Walnuts's Avatar
Whine not Walnuts
I am thinking the block and head is the same. I thought the supercharger and tune changed for the facelift.
Old Feb 1, 2018 | 10:54 AM
CSP's Avatar
CSP
Rock on. Thanks, man. That opens up some possibilities.
Old Feb 1, 2018 | 11:57 AM
RB-MINI's Avatar
RB-MINI
The tune changed to get 5hp more with pops/burbles, and the supercharger rotors were teflon coated, like a JCW without the pulley.
Old Feb 1, 2018 | 01:41 PM
Yea, not much difference, other than the coating on the SC, early design oil filter housing caps, the PCV design on the valve cover, I think there was some updates on the way the harness hooked around the engine bay, but the wires were the same.
Old Feb 2, 2018 | 01:32 PM
ONEBUNCHMIN's Avatar
ONEBUNCHMIN
Top motor mount is also different
Old Feb 2, 2018 | 01:35 PM
CSP's Avatar
CSP
Ooooo good one! Did the mount locations change as well? Or just design?
Old Feb 2, 2018 | 03:23 PM
Thinker2112's Avatar
Thinker2112
Any one know what month for MY2005 they actually started to Teflon coat the SC?
Old Feb 2, 2018 | 03:26 PM
ONEBUNCHMIN
My 2005 Doesn't have the threaded holes in the strut tower to accept the top engine mount for a pre-facelift model.
Old Feb 2, 2018 | 04:51 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I am very sure if you get a pre-05 motor and transfer your engine mount bracket (cast AL) over all will be good as if you have an 05 motor.
Old Feb 2, 2018 | 04:53 PM
MINIAC's Avatar
MINIAC
The 5th Gen Eaton M45 supercharger (with Teflon coated rotors) was used for Cooper S models fitted with a JCW Tuning Kit or built July 2004 onward.
Old Feb 2, 2018 | 04:58 PM
pnwR53S's Avatar
pnwR53S
Originally Posted by MINIAC
The 5th Gen Eaton supercharger (with Teflon coated rotors) was used for Cooper S models fitted with a JCW Tuning Kit or built July 2004 onward.
I like to call these R53.2 for easy demarcation.
Old Feb 2, 2018 | 07:37 PM
BlwnAway's Avatar
BlwnAway
^^ This ^^
The blocks and heads are the same, so as long as you keep your old motor until the car is done and running, you'll have all the things you need, pre or post facelift donor motor.
sarom058
Dec 3, 2016 07:27 PM
cargusjoh
May 31, 2016 09:55 AM
Gizmo
Feb 28, 2011 07:48 PM
Prost
R55 :: Clubman Talk (2008+)
Jan 7, 2011 11:27 AM
fensty245
Nov 12, 2010 08:39 AM
