Well I got the set of OEM Bixenon headlights that I scored here off the forums today and unfortunately the first one I opened it appears the actual projector has broken loose inside the headlight on one side. Does anyone know if the little mounts inside the headlight are replaceable or is this projector scrap?
No separate part number, I had seen them break and people said gorilla glue worked. Give it a try. You would have to get something small in there to hold them together like a small spring clamp.
