R56 Oil check on cravenspeed dipstick
Old Jan 6, 2018 | 10:57 AM
tkenupp's Avatar
tkenupp
Hello guys! Sorry about open a new thread on this issue but i'm having a really hardtime trying to read the oil level even with cravenspeed dipstick.
on the mornings on the first pull out looks like this First time before cleaning in the morning
then i insert and get this
I only got a small mark on the last hole
thanks in advance!
Old Jan 6, 2018 | 11:05 AM
CoolHands's Avatar
CoolHands
Aren’t you meant to check the oil 10 mins after the engine has been run?
Old Jan 6, 2018 | 11:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you are cleaning it off, reinserting, and it comes out clean... I would add some oil and check again. Add a half quart, recheck and see if the level reaches the dipstick. If not, add another half, and recheck again. Repeat until you see oil on the dipstick.
Old Jan 6, 2018 | 11:58 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Old Jan 6, 2018 | 07:19 PM
gjxj's Avatar
gjxj
You can check it fine hot or cold. You dont preferably want to *change* it cold.
Old Jan 7, 2018 | 07:54 AM
sani's Avatar
sani
I would say you have no oil. Add 500ml and check again. This same situation just happened to me.
sani
Old Jan 7, 2018 | 01:43 PM
minirab's Avatar
minirab
Pull it out and wait a half hour if you can. Fold a paper towel and lay it against the
crease. Accurate every time.
Old Jan 7, 2018 | 09:14 PM
tkenupp's Avatar
tkenupp
sani
In fact i was running dry. Also i found a very bad leak and i dont know if it is a turbo oil line or a oil filter housing gasket
Old Jan 7, 2018 | 09:49 PM
vetsvette's Avatar
vetsvette
Moderator
Not a bad idea to replace the turbo oil line with a Detroit Tuned Super Kit. And while you have it apart for that it is easier to replace the "O" ring gasket in the oil filter base. This kit comes with everything you need (except labor) to do both jobs.
http://www.detroittuned.com/dt-turbo...ine-super-kit/
Mzitterich
Jul 29, 2018 04:08 PM
ntprmini
Apr 25, 2015 03:34 PM
Uncl3
Oct 8, 2013 12:06 PM
Emnotek
Jun 14, 2013 06:57 PM
iss49698
Apr 2, 2013 08:50 AM
