Suspension Best replacement shocks to pair with JCW springs?
As the title states, wondering what peoples opinions are for the best replacement shocks to pair with JCW springs on a DD. I'd only like opinions from those that have done it, thanks!
You paired those with JCW? How long did they last as they aren't supposed to be used on dropped springs, even a slight drop like the JCW's. I'm running FSD's now on standard springs.
I would go with the Koni Yellows as they are proven and know they still ride pretty well.
https://www.waymotorworks.com/koni-y...rt-shocks.html
If you are on a budget you can do the Koni Orange which is the same as the Koni Yellow but not adjustable. So they are set to what the Yellow would be full soft.
https://www.waymotorworks.com/koni-s...0-r52-r53.html
You can likely resale your FSDs to offset cost too.
I have a set for sale nobody seems to want them here
Bilstien B8s. I have them pair with MINI sports suspension springs and really like them. They absorb that jitteryness that the stock sports shocks could never handle. They should do equally well with the JCW springs and they will accept a lowering spring.
QUESTION: Can they be used with stock springs.... and if so, will they give stock ride height? (ie, is the lower perch in the same location in relation to the wheel-hub-center)
If it will be lowered even using stock springs... How by how much?
From WMW site "These KONI Orange Street shocks can be used with any lowering spring offered for your MINI Cooper. "
Case1220
Mar 28, 2017 06:36 PM
MCS09
Suspension
11
Mar 16, 2010 12:30 PM
