Interior/Exterior removing JCW door sills to reuse them
Old Nov 30, 2017 | 06:40 AM
John_theCapn's Avatar
John_theCapn
Has anyone been able to remove the gelcoat JCW door sill trim pieces and not destroy them? I need to remove them to have the skirts painted and don't want to buy them again, if I can.
Would a heat gun be sufficient in loosening the double sided tape? The first thing I noticed was the thing wants to crack like glass. Would the heat help that too?
Old Nov 30, 2017 | 06:48 AM
You will need to be careful and use a heat gun. When you peel them then can bend and crinkle and crease.
There is a gel coat one and the metal checkered one. Gel coat version peels easier. Its a foam double sided tape. You will have to scrape the old stuff off the rocker as it tends to stick. Metal ones tend to crease. 51477406651 and 51710421202
https://www.ecstuning.com/Mini-2007-...nterior/Door/3
Old Nov 30, 2017 | 06:28 PM
John_theCapn
Well, it can be done, but geez, it's a pain. Lots of heat. Lots of patience. And more patience and heat.
I did crack one, but it's tolerable. Now to find some thin double sided sticky tape.
Old Dec 4, 2017 | 11:29 AM
John_theCapn
Would this be the correct tape to use to readhere them?
http://a.co/0yRjWav
Old Dec 4, 2017 | 11:46 AM
Thats what i used. Its has to be 3M. Dont get the knockoff junk. And watch what you buy on amazon. Sometimes its not the real thing.
